Rating: 5
Page 9 of 78 1 2 7 8 9 10 11 77 78
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851197 06/11/08 02:19 AM
bkg Offline
not necessary .. Toyota rear axles are larger then chev 1/2 ton ..
buddy had a 327/350hp in his rig (almost beat my Vett in a race ) ..stock toy axles and 36" swampers .. never a problem .. and I'm NOT that aggressive .
besides .. this rig is NOT a rock crawler , it will be a DD /tow rig , as I have stated !! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Shaft diameter, perhaps, but not ring gear side...
Brian K. Gallus
Re: sold the first one .. so this ones mine ... Trekker Build [Re: bkg] #851198 06/11/08 07:13 PM
G
Greg_Canada Offline
Full floaters arent gonna give you a bigger ring gear, tho... (i know you didnt say it)
89 4Runner
Re: sold the first one .. so this ones mine ... Trekker Build [Re: Greg_Canada] #851199 06/12/08 05:11 PM
Red_Chili Offline
Toyota Section Staffer
He meant the ring gear end of the axle shaft. Toy ring gears compare favorably to Dana.
FRORF's full floater conversion would have been much stronger, cleaner, and easier to execute.
For a DD with a blown 5VZ.
-Bill
Re: sold the first one .. so this ones mine ... Trekker Build [Re: Red_Chili] #851200 06/12/08 08:46 PM
bkg Offline
My bad - typo. I mean to say that the ring gear itself is larger than a Toy.
Brian K. Gallus
Re: sold the first one .. so this ones mine ... Trekker Build [Re: bkg] #851201 06/13/08 02:00 AM
CJM Offline OP
toyota alles are just as strong , if not stronger then the Chev 1/2 tons . axle sizes between the 2 are basically the same , but the chevs have a "narrowing" near the end of the axle .. creating a weak point .. Toyotas dont !!
Ring gear here , being the STOCK 4:10 ratio , and lots of "beef" should hold up excellent to the horsepower .. ( 280 est. with the supercharger we'll see)
Full floaters are obviously stronger , with load sharing at the disc end .. I just couldnt justify the price !! shipping and all adds up .. just like when i'm sellin' my stuff .. same sh!t differen product .. http://toyotafiberglass.com
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851202 06/13/08 02:59 AM
yotaman7 Offline
CJM, awesome post. Just wanted to say thanks for postin all the great pictures and descriptions. The fabrication is awesome as well. Good luck with it.
"4X4 in upper case is $X$" Quoted from http://4crawler.com/4Runner.shtml
'00 tacoma 4WD---Sold to Toyota
'93 pickup 2WD
'85 pickup 4WD
Re: sold the first one .. so this ones mine ... Trekker Build [Re: yotaman7] #851203 06/13/08 03:28 AM
CJM Offline OP
Thank you ..
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851204 06/23/08 04:37 AM
CJM Offline OP
not much to add .. started the POR treatment ...
driveshaft washed .. then de-greased .. washed again . "metal-ready" prepped , and washed as per instructions , and then the POR-15 .
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851205 06/23/08 01:51 PM
bkg Offline
Interesting POR-15 story...
was swapping out brakes this weekend from an old set of knuckles to the T. Rather, I tried. Rust got in the way.
I had POR-15'd the knuckle, steering arm and everything but the disk brake dust shield (which was powder coated) back in 1996. These parts have seen about 8-9 winters of use since then.
The POR-15 areas were still "black," but they were pealing like skin after a major sunburn... The powder coaded pieces were great.
Brian K. Gallus
Re: sold the first one .. so this ones mine ... Trekker Build [Re: bkg] #851206 06/23/08 03:19 PM
CJM Offline OP
hmmm .. I hope i'm not wasting my time .. I only have 5 years on a previous frame coat , and so far no problems
did you do the wash, clean , metal ready ... ect.. steps ?
83 Trekker SR5
NEW Trekker forum
PHP: 7.4.33 Page Time: 0.016s Queries: 15 (0.013s) Memory: 0.6568 MB (Peak: 0.7627 MB) Data Comp: Off Server Time: 2026-07-14 05:23:42 UTC
