Rating: 5
Page 10 of 78 1 2 8 9 10 11 12 77 78
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851207 06/23/08 03:32 PM
bkg Offline
hmmm .. I hope i'm not wasting my time .. I only have 5 years on a previous frame coat , and so far no problems
did you do the wash, clean , metal ready ... ect.. steps ?
I think it might work fine for you... might not, I can't say.
I spent over $350 and numerous hours prepping that dang 4Runner. I POR-15'd everything. Scrubbed it clean, washed, cleaned w/ the POR-15 cleaner, Metal Ready, then POR-15 when the parts were ready. Used two coats, even.
I've just never had good luck w/ it. Others swear by it. If it were me doing things again, I'd blast, etch prime, prime, paint and clear coat everything. But I'm a glutton for punishment as well. smile
Brian K. Gallus
Re: sold the first one .. so this ones mine ... Trekker Build [Re: bkg] #851208 06/23/08 09:10 PM
G
Greg_Canada Offline
I POR'd my frame when they were saying "right over the rust" so i cleaned it up decently and brushed it on.
First winter, i went to powerwash the frame and the stuff came right off (i powerwash my frame every week in the winter time)... from then on, i just put a layer of tremclad on every year....
89 4Runner
Re: sold the first one .. so this ones mine ... Trekker Build [Re: bkg] #851209 06/24/08 01:46 AM
CJM Offline OP
well in my experiance ...
I have had no problems . there is a procedure .. and I guess I will let you all know in about 5-9 years on how this coat goes smile
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851210 06/27/08 02:07 AM
CJM Offline OP
diff .. and extras ..
springs are in the works .. and soon the frame ..
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851211 06/28/08 01:48 AM
CJM Offline OP
springs are done ...
If all goes well ..I'll have the frame done this weekend .. smile
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851212 06/29/08 01:16 AM
CJM Offline OP
springs ..
but there is no way I'm doin' the frame this weekend .. it's 36* C (about 90* F ) outside .. so I'm goin' to the beach ! .. smile
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851213 07/08/08 12:46 AM
CJM Offline OP
so a wee bit more progress on the POR treatment ..
and I have started to "BLOW" apart the suspension .. so I could get the frame done
.. when FINALLY .. look what shows up ..
my new fuel tank ..
it's a bolt in .. and will accept the 84-89 EFI fuel pump bracket .. (mine needs a new pressure tube ) but it's all bolt in ..
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851214 07/09/08 02:55 AM
yotaman7 Offline
Tank looks good. Where did you get it from and what did it cost?
"4X4 in upper case is $X$" Quoted from http://4crawler.com/4Runner.shtml
'00 tacoma 4WD---Sold to Toyota
'93 pickup 2WD
'85 pickup 4WD
Re: sold the first one .. so this ones mine ... Trekker Build [Re: yotaman7] #851215 07/10/08 02:17 AM
CJM Offline OP
I am now the distributor ..
http://www.toyotafiberglass.com ..
this paticular tank was $275.00 .. but it is one of the more " expencive " tanks .. it's not on the site yet , so just refure to this post .
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851216 07/10/08 02:19 AM
CJM Offline OP
dont know if you can see in the previous pic or not .. but the pressure line on the sender is gone .. and the other pipe is rusted .. so
I had to fix .
I drilled out the old pipes , and started to manufacture my own .
The /84 holder didnt fit as "perfect" as I wanted .. so I bent the fuel pump holder , and fit .. bend and fit .. now it fits exactly where I want .. and to go with it .. new pipes .
bent up the PRESSURE pipe ..
and the return line
saudered , zinc'd and installed ..
83 Trekker SR5
NEW Trekker forum
PHP: 7.4.33 Page Time: 0.016s Queries: 15 (0.013s) Memory: 0.6564 MB (Peak: 0.7625 MB) Data Comp: Off Server Time: 2026-07-13 16:01:24 UTC
