Rating: 5
Page 12 of 78 1 2 10 11 12 13 14 77 78
Re: sold the first one .. so this ones mine ... Trekker Build [Re: Talon84X4] #851227 07/31/08 01:51 AM
CJM Offline OP
so not much to add today .. but a bit ..
dropped the engine back in place , and started on the transmission .. and clutch .
blasted the fork to check for cracks and such .. , and then zinc'd
on this swap , you will need to use the 3.0L throwout bearing ..
greased the fork , and inner bearing surface , and installed .
installed the pilot bearing ..
the 3.4L clutch installed ..
with these kits you get a "goofy" plastic alignment tool .. but I like to use my own .. an original input shaft .
and finally the tranny back in place ..
also mounted the starter ..
on the bottom mount of the 3.0L belhousing .. it is threaded .. so is the starter .. you I had to drill the threads on the starter so the bolt would go threw
very simple
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851228 07/31/08 05:33 AM
Bent_85 Offline
Great progress! Excellent Post!
Just thought I'd throw in my 2cents.
<img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
91 Toy 4x4 V6
85 Toy 4x4 22R
Re: sold the first one .. so this ones mine ... Trekker Build [Re: Bent_85] #851229 07/31/08 03:27 PM
CJM Offline OP
Thank you .. I appreceiate your comments ..
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851230 08/06/08 01:26 AM
CJM Offline OP
re & re'd the ATM wire harness , for the MTM harness ..
also installed the front shaft .. had to remove the transfer flange because it has 10mm GRD11 studs , and stock 83 is 8mm .. so same as the rear shaft , I had to drill .
also mounted the front of the exhaust again , to get ready to build the rear ehaust pipes , and muffler ..
also fully mounted the fuel tank , and installed senders , and pump for good ..
I think thats it ..
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851231 08/07/08 08:40 PM
P
Pyroboy Offline
Looks good, Corey!
1989 4Runner Special Edition
22RE, 5-spd.
TG 3" SAS, MC DuaLs, 4.56s, Air Locker
Hi-Clearance panels by
www.toyotafiberglass.com
Re: sold the first one .. so this ones mine ... Trekker Build [Re: Pyroboy] #851232 08/08/08 02:07 AM
CJM Offline OP
thanks ..
hope you had a good time when you were here ...
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851233 08/09/08 11:48 PM
CJM Offline OP
thought i'd post some progress pics ..
as of today Aug 9th 2008
just working on the "plumbing" getting the fuel lines bent up .. , almost done .
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851234 08/16/08 03:43 AM
CJM Offline OP
started the teardown of the original 4runner the harness came out of ..
My therory here is to strip down the harness , and use what I can ..
from the "cut " ( as seen in ths pic) on the end of the trailer .. I'm going to use the original harness - some un-needed weight .
I also have the new booster , and brake master , and clutch master ..
i'll get pics tomorrow ..
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851235 08/17/08 01:11 AM
CJM Offline OP
so as promiced .. the complete wire harness ... i'll bet this sucker weighs in @ 50lbs !!!
dont know what i'll be using .. but I wanted it in one piece ..
same here .. I know I will be using the booster , and brake master for sure .. but the rest , well ........ we will see .
and finally the front clip stripped .. and off to the recycler
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851236 08/24/08 12:06 AM
CJM Offline OP
so with family here for some holidays , and the shop being stupid busy , I havent gotten much done .. but every little bit , is a little more done .
I was working on the harness today , and got lots of it stripped ,
hooked up most of the connections , and tagged what I new .. and started cutting some of the non-ecentials , that I wont be using
and what I have cut out so far .
I have a few connections , that I have no Idea about (I didnt dissconnect).. so I'll have to do some research to figure out what they are .
83 Trekker SR5
NEW Trekker forum
PHP: 7.4.33 Page Time: 0.017s Queries: 15 (0.014s) Memory: 0.6596 MB (Peak: 0.7673 MB) Data Comp: Off Server Time: 2026-07-14 09:04:51 UTC
