Rating: 5
Page 20 of 78 1 2 18 19 20 21 22 77 78
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851307 12/24/08 06:31 AM
CJM Offline OP
so a little bit more
got the cab mounts .. "fit" .. + 1" body lift to clear the TG hoops >:(
had to cut , and drill .. and zinc .. but finally "tacked" .. and cab is now sitting on it's own ;D
now ready to "mock" up the floor .....
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851308 12/25/08 01:37 AM
CJM Offline OP
so a little bit more today .. smile working on the floors .. made some templates first .
and transfered them to steel
cut them and fit them
also started on the tranny tunnel pattern
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851309 12/25/08 02:51 AM
RatLabGuy Offline
What's wrong with the tranny tunnel you have? is there some fitment issue w/ the replacemnt tranny? i'd think the (unplanned) 1" lift would help that.
And - are you concerned about noise and/or fitment issues w/ the homemade floor pans being so flat, as compared to the original?
Question Reality.
Re: sold the first one .. so this ones mine ... Trekker Build [Re: RatLabGuy] #851310 12/25/08 03:50 AM
CJM Offline OP
I'm using the original tunel as a "template" only .. I will not be reusing it ..(as you can see in the pics).
old one wont work , just simply be Kuz I said so !
I'm still in the process of building .. so please be patient .. I still have to add some corragation , or bead roll for strengtheners to stiffen up the floor .. I will also have to build some "plates" undernieth .. I still have a ways to go ....
but I apprecieate your comments .
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851311 01/01/09 02:21 AM
CJM Offline OP
so more work on the tunnel , and a solution to the cab floor , and Trekker tub connection .....
so now with the basic "mock up" of the floor and tunnel , I can now cut the floor of the tub and build a deeper floor for the rear seat passengers
and starting a new fiberglass tunnel (templating from my new tunnel)
one issue , maybe ............ I cant find anyone in our town with a plenishing hammer .. so no floor corragations .. I guess we'll see how it goes .
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851312 01/03/09 05:49 AM
P
Pyroboy Offline
Corey,
Looks great! How will you make the transition from the steel to fiberglass floor?
1989 4Runner Special Edition
22RE, 5-spd.
TG 3" SAS, MC DuaLs, 4.56s, Air Locker
Hi-Clearance panels by
www.toyotafiberglass.com
Re: sold the first one .. so this ones mine ... Trekker Build [Re: Pyroboy] #851313 01/03/09 06:12 PM
CJM Offline OP
thanks .... there will be a crossmember undernieth for support , and the fiber floor is then bolted (originally screwed) and sealed to the metal floor .
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851314 01/04/09 02:37 AM
CJM Offline OP
and NOW ..... the fun begins smile ------ check it out ---->
cut a hole in the firewall .. and started some connections
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851315 01/06/09 09:59 PM
G
Greg_Canada Offline
I'd let you use ours... but... couple thousand km's away! lol...
why not buy a bead roller? I dont think they are TOO expensive... are they?
89 4Runner
Re: sold the first one .. so this ones mine ... Trekker Build [Re: Greg_Canada] #851316 01/07/09 02:29 AM
CJM Offline OP
bead roller wont do 14G .. I didnt relize this when I first posted !! .. but I know now .
83 Trekker SR5
NEW Trekker forum
PHP: 7.4.33 Page Time: 0.016s Queries: 15 (0.013s) Memory: 0.6623 MB (Peak: 0.7718 MB) Data Comp: Off Server Time: 2026-05-29 19:58:54 UTC
