Rating: 5
Page 21 of 78 1 2 … 19 20 21 22 23 … 77 78
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851317 01/07/09 10:57 PM
G
Greg_Canada Offline
Also, you know it isnt too difficult to build a planishing hammer? Ours we used 4x4 tubing, a long barrel air hammer, some die's and a foot actuated valve.
89 4Runner
Re: sold the first one .. so this ones mine ... Trekker Build [Re: Greg_Canada] #851318 01/08/09 02:41 AM
CJM Offline OP
my neighbor (landlord) has one sitting in the back 40 .. I think this year , I'm going to get a metal shop going .. building some "specific" metal pieces ...
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851319 01/08/09 02:42 AM
CJM Offline OP
couple of progress pics
engine compartment "mock up" continues ... Rad installed , starter is now wired as well as the alternator .
and more floor space ............
and also dash cluster "mock up"
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851320 01/08/09 06:27 PM
RatLabGuy Offline
Man, all that nice touch and clean up udner the hood - I'm really surprised you didn't repaint that brake master cylinder, it really sticks out now.
Question Reality.
Re: sold the first one .. so this ones mine ... Trekker Build [Re: RatLabGuy] #851321 01/09/09 02:38 AM
CJM Offline OP
please dont forget this is all "MOCK UP" ... there is NO WAY i'm usin' that rusty ol' master ... come on now , you know me better then that !!!!
I'm just getting an idea of where things go .. drilling holes , and mounting "ecential" 5Z pieces into the 22R engne bay . MOCK UP ...
This will all be torn apart again .. even the cab will come off again for final welding , and prep . this is just an excersize .
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851322 01/09/09 11:50 AM
trcdrunner Offline
Am I seeing thoughts of a 'glassed dash???? if so any other thoughts for the other componets (Air vents/Gauges/Switches)
hhhhhmmmmmmm
aka FireNIce
84 Runner 33" Swamper LTB, 4.30's, Spool in Rear, Lock-Right soon in front exo-caged, 4" lift.
TRCD Toys Web Site
TRCD Toys Apperal
Re: sold the first one .. so this ones mine ... Trekker Build [Re: trcdrunner] #851323 01/10/09 03:15 AM
CJM Offline OP
hhhhhmmmmmmm
<img src="/forums/images/graemlins/butwiggle.gif" alt="" /> keep em' guessin' and they will return <img src="/forums/images/graemlins/notooth.gif" alt="" /> <img src="/forums/images/graemlins/notooth.gif" alt="" /> <img src="/forums/images/graemlins/notooth.gif" alt="" />
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851324 01/10/09 08:10 AM
CJM Offline OP
ok .. working away ..
and 1 thing on the list to get done was the lower rad to engine connection ..
with the new turbo 3 core rad , there was only a wee connection between the engine and the rad .. so i ended up cutting about 3 " off and welding a "new" lip ..
and installed .. sorry .. not a good pic .
now a simple 90* to connect ..
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851325 01/12/09 02:23 AM
CJM Offline OP
for those of you whom have commented about the "rusty" master.. I thought I would get to the real replacement ..
2000 4Runner duel diaphram booster with the 1" master , and clutch master ..
the clutch master is close and actually touches in 1 spot .. I'm going to correct that when I pull it a part .
because of the size of the booster and the length of the studs , the original spacer is not usable . also installing the booster with the stock steering shaft the u-joint at the fire wall hits the booster .. so in order to accomplish the booster install , I pulled out a spare /84 shaft I had from my 2WD project .. the shaft has a ball socket , instead of a u-joint , making the "connection" much smaller .
swaping the whole steering column is not possable because of the mounting points
79-83
unbolting the lower column housing and "swaping"
the floor mount for the 83 dosnt fit the 84 lower .. so I have to "open" it up a bit ..
[img]http://i76.photobucket.com/albums/j2/bj_bumperboy/MY%20Trekker/HPIM1277.jpg[/img]
and with everything back together .. I now have "VERY" large brakes smile and should be able to "stop on a dime"
[img]http://i76.photobucket.com/albums/j2/bj_bumperboy/MY%20Trekker/HPIM1278.jpg[/img]
[img]http://i76.photobucket.com/albums/j2/bj_bumperboy/MY%20Trekker/HPIM1279.jpg[/img]
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851326 01/12/09 04:41 AM
G
Greg_Canada Offline
This should be the nicest trekker ever on the road when it's done.
I cant wait to see it <img src="/forums/images/graemlins/smile.gif" alt="" />
89 4Runner
PHP: 7.4.33 Page Time: 0.019s Queries: 15 (0.015s) Memory: 0.6619 MB (Peak: 0.7715 MB) Data Comp: Off Server Time: 2026-11-03 04:52:54 UTC
