Rating: 5
Page 22 of 78 1 2 … 20 21 22 23 24 … 77 78
Re: sold the first one .. so this ones mine ... Trekker Build [Re: Greg_Canada] #851327 01/13/09 04:45 PM
CJM Offline OP
needed a battery tray for the drivers side .. so I made one ..
not welded to the cab yet as I need to do some finish bracing .. so I'll wait untill I pull the cab off to do the final welding ..
also started "prepping" some mounts .. getting some pieces in there final location ..
fuel canister is "mocked up" cut some metal out for the perfect fit under the hood ..
shouldn't be to bad as , i'm not using a "flexy" suspension .. I doubt I will ever "touch" this mod with a tire .. I know I could run the "round" type fuel canister .. but I didnt want to .
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851328 01/17/09 01:59 AM
CJM Offline OP
made up some brackets and finally got the fuel canister mounted ..
and also the fuse box
also started on the gas pedal . the original 83 was toast .. as with most of them the hinge that mounted to the floor was rusted and beyond repair .. I didnt want to use another "floor mounted " pedal ... so I made my own
heres where I started
the bolt patterns are different and positioning is also way different , so they are NOT interchangeable .
I started by cutting the pins off of both pedals ..
first I cut off the /83 pin and welded it to the 2000 shaft .
then for the tension spring I used the post fron the 2000 , drilled a hole for the spring , and welded it to the /83 bracket .. sand blasted and started to put it back together .
put some zinc , and then some color and mounted ..
I had to drill new holes for the throttle cable and will weld up the old ones when the cab comes off for final welding and engine bay paint
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851329 01/26/09 02:41 AM
CJM Offline OP
progress has been slow as of late .. My shop is going threw some growing pains , so not much getting done threw out the week ..
but this weekend , I was back at er' ..
getting everything labled .. it's comming !!
also , checking the fuse box on the drivers kick panel .. and there really isnt much room ...
so I'm going to build a specific box or "french" the fuse box
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851330 01/26/09 04:43 PM
RatLabGuy Offline
I really do not envy you on that wiring job...
Question Reality.
Re: sold the first one .. so this ones mine ... Trekker Build [Re: RatLabGuy] #851331 01/26/09 04:53 PM
CJM Offline OP
it's not fun ... the manuals are not as good as I thought , wires posted in different areas , I have even run into different color coded wires then listed , I know it's me and not the manuals , but jeeeezzzzz ... I have little hair as it is .
looking back , I should have just stayed with the original harness , but my delema with that is that it was 25 years old ! so in the end I think it will be worth it .
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851332 01/26/09 06:33 PM
G
Greg_Canada Offline
I'm so glad i bought the ORS swap harness and brand new engine harness for my 3.4 swap.
89 4Runner
Re: sold the first one .. so this ones mine ... Trekker Build [Re: Greg_Canada] #851333 02/08/09 02:29 AM
CJM Offline OP
finally got a day off to work on my truck smile
and got the brake lines done and clutch line ....
all the brake lines are now plumbed .. even built a bracket and mounted the new proportioning valve
2 more lines to run .. fuel and fuel vapor ..
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851334 02/10/09 02:39 AM
CJM Offline OP
supercharger is here ... havent unpacked it yet tonight .. but will soon ..
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851335 02/10/09 02:43 AM
G
Greg_Canada Offline
Hey corey, if you dont mind me asking, where did you get it from and how much did you pay? I'm looking for one (PM me if it's private info)...
Greg
89 4Runner
Re: sold the first one .. so this ones mine ... Trekker Build [Re: Greg_Canada] #851336 02/10/09 04:03 AM
CJM Offline OP
my dealer program is no longer importing the 95-2002 superchargers into Canada .. go figure ???? as soon as I need one ..
anyway .. I found one on Cali craigs list , and bought it .
and why dont you have the 1/4r's listed in your sig ?
83 Trekker SR5
NEW Trekker forum
PHP: 7.4.33 Page Time: 0.019s Queries: 15 (0.015s) Memory: 0.6613 MB (Peak: 0.7700 MB) Data Comp: Off Server Time: 2026-11-02 12:28:28 UTC
