Rating: 5
Page 30 of 78 1 2 … 28 29 30 31 32 … 77 78
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851407 05/29/09 04:59 AM
drainsbe Offline
Freakin awesome build... Thanks for sharing all of your progress. <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Dave
86 4Runner, 22R-EB
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851408 05/29/09 02:44 PM
wsquaredodie Offline
Looking at your last pic brings up a suggestion I have used on both my 93T's. Instead of the chintzy plastic clip for the hood hold up rod, put a small piece of velcro in the appropriate place. Never rattles, never wears out. And you do not have to lean on a piece of plastic if your are under the hood.
trafdlo
Re: sold the first one .. so this ones mine ... Trekker Build [Re: wsquaredodie] #851409 05/29/09 03:31 PM
CJM Offline OP
thanks
and wsquaredodie , the 79-83's actually have a metal screw on , prop rod hold down .. low profile , much nicer (in my opinion) then the plastic ones that always break .
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851410 05/30/09 04:06 AM
Sounds like a good idea - but laying your big belly on velcro is much better......... <img src="/forums/images/graemlins/lol.gif" alt="" />
trafdlo
Re: sold the first one .. so this ones mine ... Trekker Build [Re: wsquaredodie] #851411 05/31/09 01:23 AM
CJM Offline OP
I wasnt going to , but I decided to finish wiring the fan .. and hook up the cooling system .. The last things I had to do , for a running unit .
I have had many times when I have done wiring (not my favorite thing) thought I had it all good .. taped and loomed only to have to take it all apart again because of some stupid mistake .
so this is why I wanted to get it running perfectly before I took it apart for the last time ,and , taped and loomed it all up .. I'm glad I did .
Today I finished the plumbing .. all clamped .. also buttened up the fan wiring . filled er' up with some coolant and flashed her up ..
I have 4 problems ...
1. the temp guage went to hot "right off the bat" wiring issue maybe .. not sure just yet .
2. amp meter dosnt work ..
3. check engine lamp - checked with my OBll reader , and have only 1 code
4. since I put on the supercharger , its running rough and really low idle ~600RPM , I think I have a vaccuum leak maybe .
I wasnt able to look into any of these just yet , but obviously will !!
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851412 05/31/09 02:07 AM
Might want to verify god ground on the electrics
trafdlo
Re: sold the first one .. so this ones mine ... Trekker Build [Re: wsquaredodie] #851413 05/31/09 02:44 AM
CJM Offline OP
I will ... <img src="/forums/images/graemlins/notooth.gif" alt="" />
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851414 06/11/09 12:32 AM
CJM Offline OP
so wee bit of progress today ... had an hour , so I was able to figure the temp sensor .. IT works now . you were right , I had unsuspectantly removed the ground wire from the combi. meter connector .
check engine lamp is still on , but now I can run it .. and did so today ..
found it running rich and I still have air temp control code .. which I believe now is the IAC valve .. iratic idle and rich .. hopefully I can check that out tomorrow .
and still have the AMP meter not working ! and that is it .
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851415 06/11/09 02:18 PM
Amp meter only works if the circuit is complete. Look for a bad connection somewhere
trafdlo
Re: sold the first one .. so this ones mine ... Trekker Build [Re: wsquaredodie] #851416 06/11/09 03:07 PM
G
Greg_Canada Offline
SO wait, do you have an ampmeter, or a voltmeter? An ampmeter has to be hooked up inline in the positive battery cable (in series).
Voltmeter would be an easy hook up...
89 4Runner
PHP: 7.4.33 Page Time: 0.021s Queries: 15 (0.018s) Memory: 0.6598 MB (Peak: 0.7641 MB) Data Comp: Off Server Time: 2026-11-02 12:27:53 UTC
