Rating: 5
Page 29 of 78 1 2 … 27 28 29 30 31 … 77 78
Re: sold the first one .. so this ones mine ... Trekker Build [Re: kewlynx] #851397 05/11/09 02:59 PM
RatLabGuy Offline
I don't think my ash tray has ever had actual ashes in it - but it's a great place to contain loose change, rnadom bolts, candy... all kind of crap that would get thrown around as soon as you leave pavement.
i liek teh idea of starting w/ a fresh flat console plate though, now you can lay it out however you want.
Question Reality.
Re: sold the first one .. so this ones mine ... Trekker Build [Re: RatLabGuy] #851398 05/11/09 03:53 PM
CJM Offline OP
Wow, you're really getting there Corey.
With all the little electronic gadgets out there, you might consider putting in a cig lighter, if not for anything else, for a solar battery charger or something. I use the one in the back of my '99 quite a bit; mostly for air pump for camping mattresses or small air compressor.
Just a thought; what do the boys think of this project? I know ya keep 'em busy! <img src="/forums/images/graemlins/cheers.gif" alt="" />
exactly .. I am going to use the 2 accessory ports from the original 4Runner .. I did keep the wiring intact for those for exactly the reason you mentioned . 1 in the front (dash) and 1 in the rear .
no ash trey , I want the room for "other things" .
I know what you mean about the "little things" being tossed in the ash trey , my DD is the same . I have thought about this , and I am going to be building a center console .. so I will have the room there , as well as cup holders <img src="/forums/images/graemlins/notooth.gif" alt="" />
not set on the lay out of the dash yet , I just know for sure , where the heater controls are going ..
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851399 05/11/09 05:08 PM
G
Greg_Canada Offline
Are you gonna throw in an inclinometer just for kicks?
89 4Runner
Re: sold the first one .. so this ones mine ... Trekker Build [Re: Greg_Canada] #851400 05/13/09 12:18 AM
CJM Offline OP
nope .
so little more to add .....
got the POWER antenna mount done ... and mounted
also .. continuing working on the dash ..
trimmed the fiber dash base
and "hammered" out a new corner dash piece , and welded ..
and started on the other side
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851401 05/14/09 12:52 AM
CJM Offline OP
made the Left lower dash plate today .. in the same manner as the right.. hammered out a piece , and welded it together .
Last piece is the center piece . Then I can start to make the "cutouts" for the switches and such .
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851402 05/15/09 01:19 AM
CJM Offline OP
got the center section done today ..
now I can lay out my switches , sterio and heater controls
then .. time for some body work and "tweeking" , paint .. 2 part foam and sewn leather top
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851403 05/22/09 01:39 AM
CJM Offline OP
not much to add ...
have been "tinkering" on it every "now and then" .
I have pulled off the back 1/2 again .. because I wanted to wire the LAST pieces .. pump and sender .. pump works awesome , sender NO .
1 of the issues is the fuel warning lamp . /83 dosnt have .. /99 does (dash cluster)
I dont know of any way to wire this issue .. so I'm going to have to use a /99 fuel tank sender and build my own sending unit .
under way
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851404 05/25/09 01:47 AM
CJM Offline OP
got the sender done today ...
here's what I had to do ...
first I made the top , just cut it out of some 12G scrap I had ..then I drilled the mount holes ..
trimmed , and finished to a perfect circle (well maybe NOT perfect .
I had a few difficulties figuring out the support .. because the hole on the tank is so small .. there was definatly some "grey matter working " but I got er' figured !!
the mount support , off-set to fit into the smaller hole
and with a little "massaging" I was able to finally "roughly" mount the sender , and stuff it into the tank .
once I was able to fit it .. I needed to support it .
so I made some little brackets , and drilled and tapped the support holes .
this is a pic of the sender as it came out of the /99 is tank ..
and after cutting the original mounts and ground off .. heres what I have now .. with the new clips new ground wire and main support I made .
and all together
and mounted and tested .. it works YEAAAAAH !!!!
so now I want to send it out for anadizing .. then I will seal the wires ..
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851405 05/29/09 01:20 AM
CJM Offline OP
installing the SUPERCHARGER ... finally .. <img src="/forums/images/graemlins/smile.gif" alt="" />
finished ..
supercharger WHINE .. is so cool .... <img src="/forums/images/graemlins/evil.gif" alt="" />
but I really have to put some coolant in , so I can run it ... this weekend for sure !!!!!
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851406 05/29/09 02:44 AM
kewlynx Offline
Dang Corey, I'm excited for ya. Gotta be killer doing it with what little spare time you have. Way to stay with it! <img src="/forums/images/graemlins/cheers.gif" alt="" />
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.032s Queries: 16 (0.028s) Memory: 0.6615 MB (Peak: 0.7886 MB) Data Comp: Off Server Time: 2026-11-03 22:11:44 UTC
