Rating: 5
Page 39 of 78 1 2 … 37 38 39 40 41 … 77 78
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJMT100] #851497 09/19/09 03:54 PM
CJM Offline OP
it was my temper <img src="/forums/images/graemlins/zombie.gif" alt="" /> I got mad at it .
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851498 09/19/09 05:32 PM
CJMT100 Offline
I see.. Scary stuff man.
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJMT100] #851499 09/20/09 01:34 AM
CJM Offline OP
once in a while .. ya just gotta "vent" ..
inanimate object's are ok in my eyes !!
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851500 10/09/09 01:58 AM
CJM Offline OP
sorry for the slow progress ...
but today I have a wee bit of an update .
started the drivers door panel , I have to re-pin the hinges , so I will be sure to post that as well .. (hopefully this weekend) but for now , this will have to do
started with removing the door and hinges
Next .. with the grinder "clipped" the edges
and off comes the skin .. there is a few spot welds , expecially for the vent window supports .. but easlily dealt with ..
New skin goes on .. and time to make it stick !!
I didnt have a mini rasp, have to go buy one .. so I called er' a day ..
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851501 10/09/09 06:10 AM
kewlynx Offline
Shakes head in awe....wow.
**ubi apis- ibi salus**
Re: sold the first one .. so this ones mine ... Trekker Build [Re: kewlynx] #851502 10/10/09 01:35 AM
CJM Offline OP
got the flanges cleaned up today .. and got the POR15 on them
also "cleaned" up the inside , and got it POR15'd
trimmed up the holes for the handle and lock
and installed and ready to "bond"
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851503 10/11/09 12:23 AM
CJM Offline OP
ok continueing on ... In order to "attach" the fiber skin .. you need to scuff the panel , where it will contact the metal shell , for as the say in the industry "tooth" , meaning .. something for the epoxy to stick to
fiber panel
metal shell , back to bare steel .
The epoxy I use in my shop is 3M panel bonder .. it's expencive , but if done propperly , it will never come apart , and they guarentee it !!
so now .. epoxied .. and clamped .. just has to cure ..
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851504 10/11/09 12:43 AM
CJM Offline OP
so now the door is "curing " ...... time to address the hinges ..
lots of play , so time for some new hinge pins .
had the hinges sitting in a pot of deluted hydrofloic acid over night
so it make sandblasting a little easier and heres the works ..
had to cut the pin , and punch it out
next , I had to drill the old hinges to fit the new bushings
both sides have to be done because , the pin is a little larger . File the " burrs " and install the new bushings .. The pin also has to be trimmed , because it was to long .
I "plug" welded the bottom of the hinge , for safty .. and a little primer ... DONE
just have to wait for the epoxy to cure .. and I can mount the door smile
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851505 10/12/09 12:14 AM
CJM Offline OP
all excited , I went in this morn. to get the door mounted .. removed all the clamps , and connected up the door handle , bolted on the hinges .. and got the door back on
Marked the position of the mirror , drilled and "nutcerted"
and put the mirror back on
Very happy with the way it turned out .. when I trim the fiberglass panels , I always trim them LARGE .. so there is enough panel to make my own panel gaps . it's always easier to remove material , then to add it . So when I do the "final" body work , I will be able to sand down the door edges , to make perfect panel gaps
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851506 10/12/09 06:24 AM
matts Offline
Are you making door skins for sale? 84 - 88? Tell us more about the hinge pins too. -- Matt
'89 4runner SR5, 3.0, auto (fun)
'93 xtra cab, dlx,3.0, 5spd (work truck)
PHP: 7.4.33 Page Time: 0.021s Queries: 16 (0.018s) Memory: 0.6612 MB (Peak: 0.7869 MB) Data Comp: Off Server Time: 2026-10-23 03:30:37 UTC
