Rating: 5
Page 42 of 78 1 2 40 41 42 43 44 77 78
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851527 12/07/09 01:51 AM
CJM Offline OP
little more today ....
started re-sizing the other side
so got it done ... this pic gives you an idea about the size i'm going for ...
and cut the tub , but didnt want to cut to much out in "one shot" .. so this way I can glass it back up and regain some rigidity
and a "test" fit
also .. started on the backs of the seats .. removed the covers and foam
and readied them for cutting .The backs are a different cut pattern , as they have the headrests .. I will still need to remove the headrest supports , and re weld them in the correct position .
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851528 12/09/09 02:05 AM
CJM Offline OP
so had a little time today .. and got the seat backs cut and tacked also removed the headrest supports and the lock support ..
got the foams cut and glued
also was able to start on relocating the lock support ..
and cutting out some of the rusted old supports
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851529 12/10/09 01:45 AM
CJM Offline OP
got the seat backs mocked up .. and i'm stoked smile ..
lines are perfect .
I'm hoping to have them work like the 4runner , with the bottoms lifting up , and the backs folding down .. so far so good .
also got some work on done on the fenders
repaired all of the cracks and lower lip + the holes previous owners have put in .. also got the new taillamp pockets in
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851530 12/10/09 04:57 PM
RatLabGuy Offline
Wait - so this thing dosn't have a flip-down tailgate?
Seems that would be annoying to get things in/out.
Question Reality.
Re: sold the first one .. so this ones mine ... Trekker Build [Re: RatLabGuy] #851531 12/11/09 01:33 AM
G
Greg_Canada Offline
If you ever sell this thing... i think i'll have to buy it...
89 4Runner
Re: sold the first one .. so this ones mine ... Trekker Build [Re: Greg_Canada] #851532 12/11/09 02:49 AM
CJM Offline OP
I will sell it ... but not cheep 10's of thousands ...
actually , it's not so bad , as you can walk right up to the back of it and get stuff out , and not have to wory about reaching over a tailgate .. it really nice actually .. But i'm going to be building a small tailgate anyway , because I want to also make the roof removable like the 4Runners .. so I want to have something to continue the body line .
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851533 12/11/09 02:50 AM
CJM Offline OP
wee bit more today ...
got the mount strips rienforced , and added a memorandum (my biz card) glassed in place smile
also got the seats all welded up .. with the locks
cut the top seat glass out to expose the rusted steel rienforcement strip .. and did some POR-15 to help prolong longjevity . hopefully i will get it glassed up tomorrow
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851534 12/12/09 06:36 AM
CJM Offline OP
so .. postin the good with the bad !! (ugly pics)
continueing on , and almost done with the cutting ...
removed the wheel well and relocated it 2" up and removed 1" from the rear , and moved it forward , which will do 3 things ..
1. remove that .. n ... hump in the middle of the wheel well (stock seat ketch bracket)
2. create an armrest for the rear passengers instead of the stock 2" arm rest pad
3. allow a 84-89 4Runner roll bar to fit
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851535 12/17/09 02:06 AM
CJM Offline OP
lots of grinding and sanding , gettin close to a finished piece .
wheel wells are now basically finished , little bit more to do . added/replaced the steel hatch support pieces , and glassed the old roll bar supports
also braced the floor as it looked like a washboard !! layed down a 24oz layer of woven roving , and then topped it off with a layer of 1.5oz mat .. floor should be flat again smile
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851536 12/17/09 05:07 AM
kewlynx Offline
OOowwweee-- that's a lotta dope Corey. Lookin' good tho'. Bet the boys hope to see this thing in your will! <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.012s) Memory: 0.6636 MB (Peak: 0.7733 MB) Data Comp: Off Server Time: 2026-06-17 13:27:17 UTC
