Rating: 5
Page 41 of 78 1 2 … 39 40 41 42 43 … 77 78
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851517 11/01/09 05:09 AM
kewlynx Offline
Nice- I like the gauge lighting. How is your parallex view for them? Looks like they're flushmounted instead of tilted?
Those other lights going under the dash then?
**ubi apis- ibi salus**
Re: sold the first one .. so this ones mine ... Trekker Build [Re: kewlynx] #851518 11/01/09 07:26 PM
CJM Offline OP
very well actually .. I can see them perfectly .. the face of the gage in the housing is slanted a bit not flat and also the lens is convex making them much easier for this old guy to see smile . and the lamps for the rear .. very rear is a dome lamp , and the other is for the rear passengers , it will light up the foot area in the back , untill the door is closed , then in 15 seconds goes out .
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851519 11/04/09 02:34 AM
CJM Offline OP
Dash epoxied and ready for the final bodywork smile
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851520 11/06/09 03:17 AM
CJM Offline OP
so today the dash bezzles .. hi-solids primed twice .. and sanded once. .. I'm STOKED .. so far , they look awesome !! smile
i'm hopin' to shoot some black on them this weekend ..
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851521 11/15/09 02:19 AM
CJM Offline OP
dash is basically ready to go for paint and trim . I still have to finalize the gaps yet .. but basically done smile
here are the pics ....
also .. trying to get all the little things done , I built the console arm rest , got it hinged and front latch , also the limit strap done .. and now also ready for trim/covering ...
also working on the shifter boot mounting .. bent up a coat hanger into a square , and got it welded today .. figured out how I'm going to mount it .. just need to make some small clips ...
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851522 11/18/09 02:23 AM
CJM Offline OP
so some pics of the shifter boot mount ..
here is the "ring" with the clips .. the shifter boot will be sewn to the ring , and the held down with the clips .. on to these studs .
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851523 11/18/09 02:52 AM
kewlynx Offline
That's a clever little bit of fab dere! <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: sold the first one .. so this ones mine ... Trekker Build [Re: kewlynx] #851524 11/18/09 05:04 AM
CJM Offline OP
tks... gotta get all the "little things" looked after as well
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851525 11/27/09 03:29 AM
CJM Offline OP
so .. not much going on .. but I have been collecting some parts .. got my front bumper finally :P .. (thanks to Adam )
also got my rear seats (thanks to Darren) I also picked up a stock 89 4Runner roll bar i'm goin to try incorporate in to the build .
also finally got my stock wiper blades and mudflaps (thanks to Paul)
thoughts for a rear bumper are leading to a 4Runner as well .. it has a straight bar with ends .. It has the "winch hole" .. but i'm thinkin' If I can get a banged up one .. I can weld up the unwanted holes , and have it re-chromed ..
and I think I have the rear licence plate lamp worked out .. I hate to think of it , but the 2008 Nissan Pathfinder has my perfect solution .
anyway .. thats where I'm at !!
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851526 12/06/09 03:16 AM
CJM Offline OP
so I was able to get to the shop today to work on my own stuff (finally) ...
pulled the top off . and the outer fenders ... got the fender inners all cleaned up , and ready to repair the cracks and add the tail lamp pockets .
also figured the placement of the rear seats and then pulled the tub off
ready to start cutting that up
also started on the rear seats .. pulled the seat covers off of the bottoms , and got everything measured and figured .
the factory 4Runner width measures 51" .. max trekker width I'm going to make work is 42" which means I'm going to cut the tub and the seats to fit .
I have measured the seats and had to cut 4.5" out of the frames .. 2.25 on each side , 3" in .
got one done today
83 Trekker SR5
NEW Trekker forum
PHP: 7.4.33 Page Time: 0.022s Queries: 16 (0.019s) Memory: 0.6607 MB (Peak: 0.7831 MB) Data Comp: Off Server Time: 2026-11-03 07:17:15 UTC
