Rating: 5
Page 43 of 78 1 2 41 42 43 44 45 77 78
Re: sold the first one .. so this ones mine ... Trekker Build [Re: kewlynx] #851537 12/18/09 02:59 AM
CJM Offline OP
yeah right !!! <img src="/forums/images/graemlins/nana.gif" alt="" />
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851538 12/18/09 02:59 AM
CJM Offline OP
little bit more today ..
I was able to cut the 4Runner bar to the correct height
and test fit
also made up the base plates .
conserned about mounting the fiberglass tub to the frame and possably creating water leaks or even stress cracks i have decided to make a "flexable" mount . Poly performance makes a kit for this (thanks for the link Robb)
http://www.polyperformance.com/shop/Cage-Tie-In-Kit-p-433.html
but of course I will be making my own
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851539 12/18/09 03:04 AM
kewlynx Offline
<img src="/forums/images/graemlins/lol.gif" alt="" /> I figured that would tweak ya. <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
**ubi apis- ibi salus**
Re: sold the first one .. so this ones mine ... Trekker Build [Re: kewlynx] #851540 12/19/09 03:26 AM
CJM Offline OP
<img src="/forums/images/graemlins/notooth.gif" alt="" />
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851541 12/19/09 03:27 AM
CJM Offline OP
so .. my version ..
just now will need to weld the "feet" to the roll bar and then the frame supports
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851542 12/21/09 06:39 AM
RatLabGuy Offline
So Corey I'm curious about something.
Given how much you have custom-fabbed thus far - why mess w/ a stock 4Runner rollbar, which you had to modify anyway, rather than making your own cooler/stronger one that may be a little less instrusive in that space?
Question Reality.
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851543 12/30/09 05:02 AM
P
Pyroboy Offline
Awesome work, Corey! Haven't checked in for a while so it's great to see what you've done. Can't wait to see the Trekker on the road.
1989 4Runner Special Edition
22RE, 5-spd.
TG 3" SAS, MC DuaLs, 4.56s, Air Locker
Hi-Clearance panels by
www.toyotafiberglass.com
Re: sold the first one .. so this ones mine ... Trekker Build [Re: Pyroboy] #851544 01/03/10 03:39 AM
CJM Offline OP
so .. as we know .. the Trekker was the "proto type" vehicle for the 4Runner .. i'm trying to stay somewhat true to that , but with more emphasis , as we now have actual used 4Runner pieces to use . building one would be easier , but I actually want you to be able to look at it , and say .. "thats a 4Runner roll bar "
hope that makes sence ?
thanks bud .. got your email while I was on holidays .. I will try to answer asap
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851545 01/15/10 02:31 AM
CJM Offline OP
been going threw withdrawls not being able to work on my Trekker , so I have been going back after the shop has closed , to get some work done ...
so working on the rear tub as well , I "attached" a 2x4 to the outside to level the mounting flange (substraight)
re-glassed-- adding 2 layers of 24oz woven roving + 5 layers of 1.5oz mat .. basically , this will make it stronger then the original steel that was in there + it should last and not rust out like the stock one !
2x4 substraight removed and flange trimed
and now the sides and topper back on for body line adjustment ... OMG sometimes I even amaze me .. it's perfect and need NO adjustment .. i'm super happy with it ....
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851546 01/15/10 02:58 AM
kewlynx Offline
ooooooooooo baby; it's startin' to look like a TRUCK!!!!!
Nice way to head into the weekend! <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.019s Queries: 16 (0.016s) Memory: 0.6601 MB (Peak: 0.7849 MB) Data Comp: Off Server Time: 2026-06-23 14:08:56 UTC
