Rating: 5
Page 44 of 78 1 2 42 43 44 45 46 77 78
Re: sold the first one .. so this ones mine ... Trekker Build [Re: kewlynx] #851547 01/15/10 04:05 AM
CJM Offline OP
yep .. thanks ...
Workin' on it this weekend ...
hope to finalise the rear cab suport and "tack" it into place
this is my goal !!!
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851548 01/17/10 01:34 AM
CJM Offline OP
got to work on the rear floor crossmember today smile
welded and bent up the pieces I need , and got it "built"
Tacked into place for now , untill I "blow" it all apart again for paint , I will then finish all the welding .
if you compare the previous pics of the seats , you'll notice the seats wernt level .. but now with the rear floor support in , smile
and Now .. I can finish the rear tub !!!!! ;D
heres the start
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851549 01/18/10 01:41 AM
CJM Offline OP
yippie .. I have a floor ;D
some essential pieces for the mock up ..
corrugated plastic , an LGD , and the fiberglass trany tunnel I made way back when ....
and some fiberglass
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851550 01/19/10 03:24 AM
CJM Offline OP
mock up today of the rear seat area .....
rear seats "loosly" fit in to place .. time to start on seat belt location + some extras ....
seatbelts and roll bar are going to be tied into the support frame (all trekkers have em) that I will be custom building .
a look at the rear seats in position as well as the new wheel well/arm rest .
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851551 01/19/10 02:55 PM
Staceman Offline
Makin' progress now! Coming along fantastic !!
Re: sold the first one .. so this ones mine ... Trekker Build [Re: Staceman] #851552 01/21/10 03:58 AM
CJM Offline OP
rear backs are now installed .. I want to still make them lay flat .. easy fix .. and that will come soon , but for now ..
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851553 01/21/10 04:30 AM
trcdrunner Offline
AWESOME build...
Wish I had the time, the resources and the SKILLS!!!
aka FireNIce
84 Runner 33" Swamper LTB, 4.30's, Spool in Rear, Lock-Right soon in front exo-caged, 4" lift.
TRCD Toys Web Site
TRCD Toys Apperal
Re: sold the first one .. so this ones mine ... Trekker Build [Re: trcdrunner] #851554 01/25/10 02:50 AM
CJM Offline OP
thanks
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851555 01/25/10 02:50 AM
CJM Offline OP
little bit done today <img src="/forums/images/graemlins/wink.gif" alt="" />
started on the frame to support the tub , and tie into the roll bar and seat belts
started with building the main supports .. and yes the tops are NOT level . This is due to the uneven fiberglass floor .
ready to go (4 built )
starting to "piece" it all together
drivers side
passenger side is different , because of the fuel filler tube .. had to be routed over top .
all sectioned together and ends plugged ...
I have too very strong mounts
and mounted
still have to build the cross bars ... But it will have to wait till after I pull the tube off for rienforcing ..
the glass will add to the thickness of the tub , so I cant build the final floor support untill the tub is done ..
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851556 01/31/10 04:59 AM
CJM Offline OP
excellent day ...
got my check list done...
feet welded on the bar
and my goal today was to have the seats basically done..
I have welded the locks and covers .. (you can see in the pic)
lock button supports welded
headrest supports welded
seat back cushions "carved" and fitted
also got the roll bar mounts done.. well tacked anyway ...
I decided I didnt need the "swivel joints" anyway .. the sub frame is mounted on rubber bushings , and the whole tub will flex as a unit .. good to go !!
also started work on the rear tub member ... I dont think the thickness of the glass will be a problem , as the underside on this section is almost done anyway ..
still have to weld it ... but heres were I finished up the day at
sorry for the crappy pics... my "good" camera took a dive for the worst .. so i'm dealing with my phone for now ..
83 Trekker SR5
NEW Trekker forum
PHP: 7.4.33 Page Time: 0.024s Queries: 15 (0.021s) Memory: 0.6617 MB (Peak: 0.7869 MB) Data Comp: Off Server Time: 2026-07-13 20:35:58 UTC
