Rating: 5
Page 46 of 78 1 2 … 44 45 46 47 48 … 77 78
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851567 02/23/10 02:34 AM
CJM Offline OP
so a little time for a wee bit of work on the last bits ..
I have finished the moulds for the kick panels .. hopefully tomorrow , I can start making me a set ..
also working on the rear hatch trim panel mould ..
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851568 02/26/10 02:20 AM
CJM Offline OP
so , kick panels are done.. I was only able to "fit" one side because I need to finish up the wireing ..
but here's what they look like ..
and installed
and I also decided to get a NEW hood .. just because everything else is new smile
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851569 02/26/10 03:55 PM
Staceman Offline
This rig is gonna be Gorgeous! Can't wait 'till she's finished.
Re: sold the first one .. so this ones mine ... Trekker Build [Re: Staceman] #851570 02/27/10 02:45 AM
CJM Offline OP
thanks .. actually gonna start the teardown for inner paint tomorrow .. gettin' close smile
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851571 02/27/10 08:07 PM
Bent_85 Offline
Excellent Build!
Can't wait to see when its done!
PS I'm the 33333 viewer! <img src="/forums/images/graemlins/lol.gif" alt="" />
91 Toy 4x4 V6
85 Toy 4x4 22R
Re: sold the first one .. so this ones mine ... Trekker Build [Re: Bent_85] #851572 03/01/10 03:21 AM
CJM Offline OP
and so .. The body work begins ..
started at the front .. with the bumper .
becuse of the 1" body lift .. the front bumper didnt quite sit right .. so I made some 1" extension brackets and welded them to the bumper supports .. legthed some spacers for the other mount .. and viola .. front bumper done ..
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851573 03/04/10 04:17 AM
CJM Offline OP
body work has started ..
little time today to work on the valance..
I wanted a custom piece .. reasons are .. well I just have sooo much time !!!!!
the original center mount is no longer there , so holes would be mute and I dont like the transision between the side mounts
so the plan is .. to use a 2WD valance .. (it has a deeper center and also lines up with the grill ends .. beauty body lines ) The 2WD valance mounts differently , and is also shorter , and also has a center support ..
so .. heres the start ..
cut off the center support .. and "bent it" to fit better ..... smile
I will also get rid of the mounting bolts .. and have a "smooth" trasition between the valance and the fender .. hammered a new piece to fit ..
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851574 03/06/10 02:50 AM
CJM Offline OP
continueing on with the valance ..
I finished up welding the end pieces on , and a little bondo .. and a first coat of primer .. still lots of sanding and finishing .. but you get the idea .
I will be making a mould for it ... as the fiberglass will be less flimsy
also finished up the rear hatch cover finished today smile
VERY happy ... and WAYYYYYYYYYY stronger then the flimsy plastic piece
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851575 03/08/10 02:28 AM
kewlynx Offline
Am just goin' 'wow' all the way Corey. Holy bats!
**ubi apis- ibi salus**
Re: sold the first one .. so this ones mine ... Trekker Build [Re: kewlynx] #851576 03/09/10 04:04 AM
CJM Offline OP
so continueing on with body work and finishing ..
I took apart the rear seats and readied them for new covers .. and "buttoned" up the modifications to the supports and levers .
cut and welded .. and sandblasted , and zinc'd .. ready for some color
also tore apart the front bumper that took me a year to find..
got the supports and underside of the filler panel sandblasted and cleaned up .. ready for some POR-15 to seal .
and done
also cleaned up the inside of the bumper , and scuffed the chrome , and zinc'd
and polished and buffed , and waxed the front ...
almost ready to put it back together , just need some color on the topside of the filler smile
83 Trekker SR5
NEW Trekker forum
PHP: 7.4.33 Page Time: 0.019s Queries: 15 (0.016s) Memory: 0.6614 MB (Peak: 0.7680 MB) Data Comp: Off Server Time: 2026-11-01 22:31:36 UTC
