Rating: 5
Page 45 of 78 1 2 43 44 45 46 47 77 78
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851557 02/04/10 02:24 AM
CJM Offline OP
got a wee bit of work on the rear lower seat hinges today ..
I took the original 4Runner lower seat hinges and cut them down
then welded up 1 of the brackets .. tacked them on .. and did a test fit .. COOL !!! it's going to work awesome smile
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851558 02/06/10 02:10 AM
CJM Offline OP
1 more thing buttoned up today ...
made some "pockets" to seal the seatbelts from the elements ..
how the seat belt fits !!
and installed
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851559 02/08/10 01:43 AM
CJM Offline OP
some work on the seats today ....
got the hinge holes welded up , ground and sandblasted again smile
all welded to the seat frames ....
and installed
and working awesome smile
also built a "locking" post for the seats .. so they will work like factory
and installed
and working great ... took some time to build this and make it work properly ..
I also started the new front kick panels .. little sneek peek
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851560 02/09/10 02:44 PM
Staceman Offline
Coming along great Cory <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: sold the first one .. so this ones mine ... Trekker Build [Re: Staceman] #851561 02/12/10 02:45 AM
CJM Offline OP
thanks smile
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851562 02/12/10 02:46 AM
CJM Offline OP
ok .. so a little work on the door today ..
got the old original unit stripped and in pieces
some measurements for location refferance
and the main frame re-welded and sandblasted
also while the frame was in sandblast .. I worked on polishing the window alum. piece .. as some may remember .. I'm going with a strong chrome theme smile . ....
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851563 02/13/10 02:39 AM
CJM Offline OP
got some epoxy on the steel .. and some hi build on the plastics smile
i'm going to make a mould of the inner plastic trim .. fiberglass will be stronger and easier to repair if necessary .. I dont know why Winnabego didnt do this in the first place ?
anyway .. a pic
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851564 02/18/10 02:04 AM
CJM Offline OP
one of the last pieces I have to make .. kick panels ..
so I have now done a little bit more work on them .. because of the body computer on the drivers side , and the computer on the passenger side .. stock would not sufice any more , so as in the previous pic , I made a template , and built it to fit .. primered , and being sanded .. almost ready for moulds ..
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851565 02/18/10 03:40 PM
RatLabGuy Offline
Corey, what substrate do you use for making those molds? is that clay?
Question Reality.
Re: sold the first one .. so this ones mine ... Trekker Build [Re: RatLabGuy] #851566 02/18/10 04:29 PM
CJM Offline OP
nope it's gelcoat ..
made a flat fiber piece as shown a couple of posts up , glued some wood pieces , and filled with bondo .. and gelcoat to sand ..
83 Trekker SR5
NEW Trekker forum
PHP: 7.4.33 Page Time: 0.022s Queries: 16 (0.019s) Memory: 0.6618 MB (Peak: 0.7883 MB) Data Comp: Off Server Time: 2026-07-13 12:36:53 UTC
