Rating: 5
Page 48 of 78 1 2 … 46 47 48 49 50 … 77 78
Re: sold the first one .. so this ones mine ... Trekker Build [Re: RatLabGuy] #851587 03/26/10 04:19 AM
CJM Offline OP
3 years ..
this is the "time limit"
unfortunatly , I have not had the time to do some of the things I wanted to do ..
I have other projects in the "line up" waiting to get there time in the shop as well .. so it's time to wrap the trekker project up and move on
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851588 03/27/10 01:33 AM
CJM Offline OP
so the rear tub has now been removed , so I can now finish the glass work .
Tub support also removed , and I was able to finish the welding on it some POR 15 and it'll be done and ready for reinstall
engine bay is almost stripped ..
cab is almost ready to come off smile
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851589 03/27/10 07:04 AM
CJM Offline OP
so friday night TV .. no good shows and board so back at er'
a pic of the tub .. ready for the final cut outs and glassing..
also POR'd the rear frame support and other goodies smile
and started on the wire harness ..
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851590 03/30/10 01:43 AM
CJM Offline OP
some work on the weekend I neglected to post ..
wire harness is comming along smile
also today , I got the tub trimmed up , and basically finished the topside ..
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851591 03/30/10 01:52 AM
bkg Offline
Corey -
Been wanting to ask for a while. How is the 'glass box attached to the cab? What will keep it from flexing at that joint and cracking?
thx!
Brian K. Gallus
Re: sold the first one .. so this ones mine ... Trekker Build [Re: bkg] #851592 03/30/10 03:11 AM
CJM Offline OP
as with the winnabego mounting .. it will be "mechanically" fastened .. the differance is in the rubber mounts and the frame I have made , The rubber mounts are a soft /flexable "puck" which will allow the rear tub to flex with the cab ..
however , only "real time" testing confirm ( I hope I'm right smile )
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851593 03/31/10 01:23 AM
CJM Offline OP
got the speaker holes sealed , and the seat belt covers on ..
also got the bottom of the steel rienforcement exposed .. cleaned and POR-15'd
built the jack, tool and GPS box built .. (hidden under the seat when done)
and will be ready for FINAL glassing tomorrow ..
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851594 04/01/10 01:24 AM
CJM Offline OP
yaah !!!
got the tub all done today ... <img src="/forums/images/graemlins/smile.gif" alt="" />
floor is rienforced w/24oz woven and a couple layers of 1.5 oz mat
storage box is also done ..
also got the floor welded .. and now I can remove the cab to finish up all the grinding and welding underside
I want to get the body work VERY close to completion .... so I want to keep the cab on for a bit yet
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851595 04/01/10 03:37 AM
kewlynx Offline
Solstice run for the maiden voyage Corey!!! <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
**ubi apis- ibi salus**
Re: sold the first one .. so this ones mine ... Trekker Build [Re: kewlynx] #851596 04/11/10 02:06 AM
CJM Offline OP
dont know !!
83 Trekker SR5
NEW Trekker forum
PHP: 7.4.33 Page Time: 0.024s Queries: 15 (0.019s) Memory: 0.6603 MB (Peak: 0.7679 MB) Data Comp: Off Server Time: 2026-11-03 11:40:42 UTC
