Rating: 5
Page 58 of 78 1 2 … 56 57 58 59 60 … 77 78
Re: sold the first one .. so this ones mine ... Trekker Build [Re: masheen] #851687 08/07/10 02:04 PM
Elbow_Greese Offline
What Corey has there are sealed enclosures. Makes for a tighter bass, cleaner sound, but as you know, not as loud.
As long as the volume inside the box is correct, should sound very nice!
1986 Pickup extracab longbed "Woody edition"
SAS - 33's, 5.29's, lockright rear.
02 IS300 SportCross - my "DD"
94 2wd v6 extracab
04 Outback Wagon- wife's/family car
Re: sold the first one .. so this ones mine ... Trekker Build [Re: Elbow_Greese] #851688 08/07/10 03:44 PM
CJM Offline OP
correct .. not going for "loud" .. but crisp nice sound , something to listen to or my passengers can watch a DVD , on those long trips to the car shows smile
I measured up the box and took it into my "sterio guy" and the subs are what he recommended for the box/volume .. no ports , no partitions
I do have to remove the power block from the box though , as it is to close to the crossovers on the l side , I'm sure it will create unwanted noise if I dont
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: masheen] #851689 08/11/10 04:15 PM
G
Greg_Canada Offline
Just curious Corey, but from the pix you posted, I don't see any air ports in your speaker enclosure. As far as I know, speakers gotta breathe. I built 6x9 enclosures for mine and drilled a 3/4" hole in the side of each. I have no idea what size hole is best suited for a given speaker size. With my stereo cranked up, the air that gets pushed through the hole is pretty substantial! Yours will push much more and if there's no where for the air to go, your speakers won't move like they should and the sound will suffer. Just my opinion, but I could be wrong...... I'm with many others here; great build and awesome documentation on your build! You could write a book!! LOL
Speakers you want to be sealed up (will make the lows sound better and give them better power handling).
Subs can be either or, i've got mine in a ported box right now but i dont like it that much, want to go sealed.... it sounds odd at certain outputs...
Power Block isn't in too bad of a location, You should... be fine.
89 4Runner
Re: sold the first one .. so this ones mine ... Trekker Build [Re: Greg_Canada] #851690 08/16/10 01:31 AM
masheen Offline
Thanks guys, you educated me! I'm gonna get a couple of 3/4" plugs for the port holes I made and listen for the difference in my system.
85 4x4,22r Carb, BFG 33x12.5/15x10 Rocket Startrack rims, 2" Body Lift, Rancho Springs(3"f/2"r), stabilizer & adj tork rod, Skyjacker adj drag link ,Bilstein shox, Line-x'd where it counts, KC HiLites, grill guard, roll bar, dual quad rear bumper.
Re: sold the first one .. so this ones mine ... Trekker Build [Re: masheen] #851691 08/16/10 01:33 AM
CJM Offline OP
so yippieee ...
carpet install started ...
underlay down , and finished ..
and carpet started
and now removed for sewing ..
should be back in tomorrow for good smile
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851692 08/16/10 07:05 AM
Oyaji_Jon Offline
So, THAT's how it's REALLY done... <img src="/forums/images/graemlins/kewl.gif" alt="" />
That's talent!
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851693 08/19/10 12:22 AM
chpfx Offline
Hey Cory the treker is coming along great, however I was wondering why didn't you have the bed blasted and painted before mounting as you did the cab?
Re: sold the first one .. so this ones mine ... Trekker Build [Re: chpfx] #851694 08/19/10 02:00 AM
CJM Offline OP
Thanks guys ...
chpfx - I didnt "blast" the bed because it's fiberglass . Sandblasting fiberglass is never a good idea as the media has a tendancy to imbed it's self into the panels .. i'm going to mechanically strip the old paint on the rear ..
As I have mentioned , I didnt paint the out side , because of my shop conditions .. not enough room .. I already have to scraches on the primed surfaces .. I would be real choked if the scraches were in the paint !!
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851695 08/19/10 02:08 AM
CJM Offline OP
sorry for the delay on my posting .. I took a day off smile
anyway ..
my Uhpolstery guy .. Tony .. finished sewing up the carpet , so time to install ..
still a little more to do .. but almost done the carpet
sorry for the crappy pics .. one day I'll get a real camera again !!
83 Trekker SR5
NEW Trekker forum
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM] #851696 08/19/10 03:01 AM
G
Greg_Canada Offline
Looking good.
About the blasting, the guy i use says he can do / has done fiberglass (corvettes) and it comes out great. He doesn't use sand, he usually uses baking sodas, but uses something with even less grit for the fiberglass, and apparently it turns out great. Do you have any soda blasters in your area?
89 4Runner
PHP: 7.4.33 Page Time: 0.024s Queries: 15 (0.020s) Memory: 0.6576 MB (Peak: 0.7648 MB) Data Comp: Off Server Time: 2026-11-03 12:23:21 UTC
