Heat not working when stopped....help!!! #851897 12/09/07 05:59 AM
E
enutter Offline OP
Heat works great after it warms up until I stop at a stoplight. Then it just blows cold air. Anybody know what the deal is?
Re: Heat not working when not moving....help!!! [Re: enutter] #851898 12/09/07 10:06 AM
Davepet Offline
Well, sounds like a thermostat that isn't closing properly to me.
Dave
Re: Heat not working when not moving....help!!! [Re: enutter] #851899 12/09/07 06:55 PM
yota4runna Offline
Does the temp gauge on the dash come up to the middle? If so, thermostat is probably OK. Sounds like low coolant, or a trapped air bubble.
Re: Heat not working when not moving....help!!! [Re: yota4runna] #851900 12/10/07 05:21 AM
E
enutter Offline OP
Temperature guage is right in the middle. Coolant level was just checked. How would one go about getting rid of this bubble?
"E" Nutter
1988 Toyota 4runner 3.0 V6, some mods
"JUST SAY NO TO NWOR"
Re: Heat not working when not moving....help!!! [Re: enutter] #851901 12/10/07 05:23 AM
Adam F Offline
Park the truck on an incline, or jack up the front end. Make sure your front and rear heat selectors are set to HOT. Remove the radiator cap (make sure truck is cool) and start the engine up. Let it get up to temperature. Careful, you may spill some coolant out in the process. If there is a bubble, you should see it come out of the radiator.
97 4R, stock, daily driver
PHP: 7.4.33 Page Time: 1.648s Queries: 14 (0.009s) Memory: 0.6033 MB (Peak: 0.6676 MB) Data Comp: Off Server Time: 2026-11-18 11:43:35 UTC
