Stock axle ratios #853128 12/15/07 10:04 PM
JTW Offline OP
I'm aware that the 91 troopers came with either 4.56 or 4.77 but how do you tell what you've got? Big tire package came with 4.77 but how do you know if you got the big tire package? I've only owned it for 2 years so who knows what tires have been put on it since it rolled of the factory floor, I've got 35's on it now.
One more thing, did all the LS models come with limited slip diffs? Cause I've got the LS and can't tell if it's limited slip or not, just want to put a locker in it.
Thanks
1991 Trooper, 3.4L, holley tbi, 3" body lift on 33" bfg AT's, indy HD lift shackles, G80, MUA 5, Power windows and locks. http://www.cardomain.com/ride/3133352
Re: Stock axle ratios [Re: JTW] #853129 12/16/07 03:41 AM
BigSwede Offline
For the LSD, check the option codes on the firewall plate for G80. (There also is a code for big tire option, but I don't remember what it is.)
Or, jack up both rear tires and see firsthand.
Serenity now!
Re: Stock axle ratios [Re: BigSwede] #853130 12/16/07 04:39 AM
JTW Offline OP
Thanks.
Re: Stock axle ratios [Re: JTW] #853131 12/16/07 07:45 AM
Gizzy42 Offline
4.56 gears should have an option code of HC6 and 4.77 should have option code S2J. Wide tire option is code 6NZ but isnt usually listed on the option plate.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO on US Wheel 94 series
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 50 series SUV 2.25"
There is a very fine line between "hobby" and "mental illness." - Dave Barry
PHP: 7.4.33 Page Time: 6.039s Queries: 15 (0.004s) Memory: 0.6018 MB (Peak: 0.6576 MB) Data Comp: Off Server Time: 2026-06-23 11:03:46 UTC
