Transmission Mount #853426 12/16/07 11:38 PM
dylanb Offline OP
I don't think it is, but is this what my transfer case mount should look like?
I pulled it because the transfer case has excessive movement and it looked like maybe there was a sleeve missing from this mount. There is a sleeve on the bolt that runs through it, it just seems way too small to me. Part number on the mount is mb260676, which turns up as "engine mounting torque strut". It came off the drivers side of the xfer case. Thanks for your help guys
Dylan
85 4x4 Pickup, 267K, 4d55 Conversion, Sway-A-Ways, Dual Batteries
Re: Transmission Mount [Re: dylanb] #853427 12/17/07 12:20 AM
sparkem Offline
I think that is the "transfer case roll stop." All of mine were like that with the big center hole. I know they make new ones with extra rubber in them. Check your actual Tcase/transmission mount, mounted on top of that cross member. Mine was completely severed after 15 years. There is a small metal strip bolted through it too for when they fail. Check your motor mounts too.
Re: Transmission Mount [Re: sparkem] #853428 12/17/07 02:29 AM
Happy Birthday Chris_J Offline
Yea thats the roll stop. Swapped mine out when I did my tranny mount. Its buried above your skidplates and bracket PITA to get to I think.
Re: Transmission Mount [Re: dylanb] #853429 12/18/07 06:30 PM
G
graeaglecrawler Offline
i put a rubber hose over the bolt and reinstalled it.
'91 montero a/t cranked t-bars 31x10.5x15 212k
'90 toyota extra cab 320k v6 5 speed 31's 4x4
'99 expedition 17" alloys v-8 207k 4x4
'88 BMW 325iX 247k AWD
'59 Willys Jeep Koenig PTO winch and hardtop 28k
Re: Transmission Mount [Re: graeaglecrawler] #853430 12/18/07 06:41 PM
4ePajero Offline
It is not a mounting, but a safety feature that will prevent the transmission from separating from the chassis in the event of a roll-over.
The rubber in the roll-over catch-all is not rigid enough to act as a mounting.
Somebody previously posted a photo of a brand new one which looked much like yours.
Don't ascribe to malice anything that can be adequately explained as stupidity!
Pajero LWB Gen1 3.2 Di-D TD Engine
33" Bridgestone D694s
2" Lift
Front Runner Rack
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6064 MB (Peak: 0.6713 MB) Data Comp: Off Server Time: 2026-06-21 01:02:44 UTC
