Timming
#854242
12/20/07 06:48 PM
I live in Denver-ish. I was currious if There would be any bennifit to bumping the timing up a little? It doesn't knock or anything with the current stock settings with 85 octane. What should I expect if I bump it up? I don't want to screw up the computer, but would like to get the most out of the motor.
Does anyone know the limit to timming advancement. I for shure don't want to pass it.
87 Toyota 4Runner-RV Head, Custom Grind Cam, Doug Thorley Header, Keith Black Pistions, 2 1/4" Magnaflow cat, Dynomax Exhaust 2003 Toyota Matrix XRS-Injen CAI
Re: Timing
[Re: GOI87]
#854243
12/21/07 05:39 AM
I see you have some tweaked cams on your rig; you might want to give this article a good reading and see what you think. Might not be exclusively a timing issue, those this would affect it. EB might like this one. Degreeing a camIf you decide to start messing with the timing, I would strongly suggest you take a before and after reading; remember your jumper--- so if it's messed up, you can at least whip the gun out along side the road to reset it back to a more agreeable setting. Stock tires or no?
Re: Timing
[Re: kewlynx]
#854244
12/21/07 05:39 PM
I remember reading that a while back. I was planning on keeping the wrench, jumper and the timming light in the truck. "Just in case" I thought there was another article on here about Timming and I can't find it. Something about finding where the engine "pings" then back it off a couple degrees, and thats where your max power/efficiancy is. I though EB wrote it but I'm not sure so don't hold me on it. I like where My power band is now. So I don't see the need for "tweaking" the Cam. FYI...I'm running 31's x 10.5. I know I should regear to ~4.88 but don't have the funds. If you all want to see pictures of It go to my myspace page. http://profile.myspace.com/index.cfm?fuseaction=user.viewprofile&friendid=147704324
Re: Timing
[Re: GOI87]
#854245
12/23/07 03:34 PM
J Roll Me Over
Try searching for "timing" rather than "timming"...
Not trying to be the spelling police, but correct spelling usually helps when searching.
Re: Timing
[Re: GOI87]
#854246
12/24/07 02:27 AM
Open up your viewing in the Toyota Tech archives; likely you'll find it there.
