Re: sea foam [Re: ovrrdrive] #854599 12/25/07 09:50 PM
MAC Offline
The best cleaner for carbon/varnish deposits I have ever used is Goodwrench Top End Cleaner. I believe it came out in the 80's when they had massive carbon problems particularly with their POS 4 cylinder engines. I don't know if they even make it anymore as it may have every carcinigen known to man in it. I have one vintage can left. The GM part # is 1052626. In Canada 993026.
Re: sea foam [Re: ovrrdrive] #854600 12/26/07 02:45 AM
Adam F Offline
Didn't do anything for me really either. It works at least as well as STP gas treatment.
It's basically a modern day snake oil with a huge following.
I agree.
But it does disolve carbon pretty good. I sprayed some on some spark plugs from my 2 cycle boat, and it disolved the carbon off pretty good.
But they act like it will remove "carbon deposits". Yea right. When I had my intake off of my 3vze, the only thing that would remove the carbon was a chisel. I sprayed everything on it, and even used a wire brush, and it wouldnt come off. I had to take a chisel small hammer and chip it away.
97 4R, stock, daily driver
Re: sea foam [Re: Adam F] #854601 12/27/07 07:40 PM
Red_Chili Offline
Toyota Section Staffer
Steam will take that carbon RIGHT off. DAMHIK. <img src="/forums/images/graemlins/drunk.gif" alt="" />
One of the tests for a leaking HG is scoping the cylinder and looking for a clean piston crown. Yes, carbon is hard to scrape off, but with heat, compression and temperature it is an entirely different ball game. I see no reason to think Seafoam wouldn't do at least as well as steam.
-Bill
Re: sea foam [Re: Red_Chili] #854602 12/27/07 10:41 PM
Adam F Offline
Yea, I've heard of people sucking water in the vacuum line just like you do seafoam.
Re: sea foam [Re: Adam F] #854603 12/29/07 05:01 AM
wsquaredodie Offline
If you do the water treatment (steam) you have to be very careful. Water DOES NOT compress. Therefore, using water or steam will increase compression factors dramatically. In the old days with 8 to 1 ratios you could get away with it, Used to use a spray bottle into the intake while running the motor at elevated rpm's. All kinds of crap came out of the exhaust. Just be careful. We only used it when there was considerable deiseling after turning off the ignition.
trafdlo
Re: sea foam [Re: wsquaredodie] #854604 12/29/07 05:36 AM
OOP'S Offline
A few good straight line runs at WOT through all the gears does wonders for carbon build up. Quality gas also helps a lot.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: sea foam [Re: OOP'S] #854605 12/29/07 07:06 AM
G
Greg_Canada Offline
i do it about once a week.. to clean the carbon <img src="/forums/images/graemlins/ignore.gif" alt="" />
89 4Runner
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6279 MB (Peak: 0.7189 MB) Data Comp: Off Server Time: 2026-06-07 09:30:54 UTC
