Re: Brake booster leaking, or gasket vac leak? [Re: jbclem] #855435 01/08/08 05:22 PM
Vanishing_Point Offline
I didn't get any of the messages. Money order would be fine.
PM sent.
Re: Brake booster leaking, or gasket vac leak? [Re: Vanishing_Point] #855436 01/11/08 12:57 AM
jbclem Offline OP
Matt, I've sent recent two messages but they aren't showing in the Private messages sent column. So I'll duplicate them here:
I'd like to take the coil also, but here's a description to make sure it's that same. Part number: 90919-02106. The coil is a stubby cylinder, 2-3 inches long, with a flat sided high tension tower rising up from the cylinder. Below the receptacle for the high tension cable are two plastic projections that house the male prongs that take the 2 wires from the igniter. The igniter is below the coil. The coil is inside a horizontal square metal frame.
I don't trust the PM system here, hence the duplication. Here's my email also: [email]jbclem1@charter.net.[/email]
John
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.5948 MB (Peak: 0.6431 MB) Data Comp: Off Server Time: 2026-06-07 13:04:05 UTC
