Best motor mounts for the money
#855589
12/28/07 11:39 AM
My driver side motor mount is blown out.. nothing new to you guys, I'm sure. So, I'm just gonna replace both. Not wanting to get crappy stock ones so I'm trying to figure out what kind of personal experiences yall have with other brands. What's good, what not to get. Pricy vs affordable. I hear the M.O.R.E. Bombproof mounts are pretty good but vibrate a hell of a lot before worn in. Just trying to look at my options other than crappy stock ones.
Thanks
'99 Toyota 4Runner Limited
RP Black Widow|8K HID Kit|265/75 Federal MT|Cobra NightWatch CB|Fosgate Sound
Re: Best motor mounts for the money
[Re: JWaldz]
#855590
12/28/07 04:39 PM
The stiffer the mount the more vibration they transmit to the frame.. If a daily driver I'd go with the stock type for my own comfort. If only used off road then maybe even welding the plates together would be Ok! If those lasted 12 years maybe they aren't so bad after all. Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: JWaldz]
#855591
12/29/07 03:07 AM
I have MORE motor mounts on the 94 YJ Jeep. Never noticed any vibration(s); maybe it's different on the XJ Cherokee? No "worn in" period, the mounts have been good since installation. I did have the OE motor mount screw/bolt back out, just noticing it in time to avoid any serious problems. Sometimes, OE is crap! <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: Fred Blackstone]
#855592
12/29/07 03:17 AM
I had MORE mounts on my 93 YJ. And recently put them on my 99 XJ. The vibration is noticeable, but it is defineteley not unbearable, and you will get used to it quickly. The vibrations are only really felt while idling, because while I am moving, my 33" off road tires make enough vibrations already. I would say go for the MORE mounts.<img src="/forums/images/graemlins/kewl.gif" alt="" /> Mine have done great. They didnt look worn at all when i took them out of my YJ, and they have been doing perfect in the XJ.
Your road to glory will be rocky, but fulfilling. - Panda Express fortune cookie
94 YJ. no lift...YET
[Re: the_other_guy]
#855593
12/29/07 05:02 PM
I used the pro thane motor mounts for 304 V8 in the CJ and they work good. Got them from 4wd hardware
84 CJ7 304 HEI 35 BFG,s rear dana 60 with detroit locker,Viar compressor, fibreglass body, 2 1/2 spring lift, TF999auto, Warn 8000 winch, Plus a cool little trailer on 35,s. JEEP stands for just empty every pocket
