High Idle
#856548
01/02/08 12:06 AM
1990 pickup 22re 5 speed with A/C I initially wanted to check the timing because the idle has been stumbling and also stumbles during acceleration.
I jumpered Te1 and E1 to check my timing, and the idle was high. Even with the idle screw turned all the way in, it's running at around 950-1000 RPM warmed up. Goes a bit higher when I remove the jumper.
I've got the TPS adjusted correctly. It's throwing a code 43. I'm guessing it's showing that code because I've installed a push button start so the key hasn't been in start every time it's started. That the only code flashing.
Any ideas why the idle is high or what I should look at next?
Fur clog in the sausage grinder
Re: High Idle
[Re: grandeyota]
#856549
01/02/08 01:16 AM
i had the same problem,,,it was a bad t-stat
Re: High Idle
[Re: grandeyota]
#856550
01/02/08 01:51 AM
try burbing the radiator. it sound like there is are in the throttlebody where the coolant gos. also check your hoses right there for leaks. you can see if the t stat is working when you burb the rad
Re: High Idle
[Re: aptech]
#856551
01/02/08 03:11 AM
Sorry to be new, but what do you mean by burb the rad?
Re: High Idle
[Re: daveowen]
#856552
01/02/08 03:16 AM
Burp the radiator. Put the truck on an uphill incline or a couple 2x4's. Take the radiator cap off and run the truck for about 20 minutes with the heat turned ON (circulates the core). Air will find the highest point at the radiator.
We consider this to be a good practice if messing with the coolant system/head.
Re: High Idle
[Re: kewlynx]
#856553
01/02/08 05:24 AM
I'll give that a try in the morning! Thanks for the replies. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: High Idle
[Re: grandeyota]
#856554
01/03/08 02:30 PM
How much of an incline is needed to do this? I tried it in my driveway (steepest thing around) and didn't notice any change in the idle. Do I need to elevate the front more?
Re: High Idle
[Re: grandeyota]
#856555
01/03/08 02:41 PM
See this topic - I had the same issue and I went through just about everything in order to figure it out.
93' Toy xCabbobbed > 22rEB > w56 > stock duals > SAS > 4.88's > 37's
Re: High Idle
[Re: Kaptain]
#856556
01/03/08 04:01 PM
D'oh!!!! I had this same issue a few years back and forgot all about the throttle body. Gonna have to give that a try when I get home. Good thing I slowed down on drinking when I did. <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> Thanks for the reminder
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6230 MB (Peak: 0.7096 MB) Data Comp: Off Server Time: 2026-10-22 07:02:09 UTCValid HTML 5 and Valid CSS
