Will a 84 G54B 2.8 fit in a 88? #856656 01/02/08 04:24 AM
billygoat Offline OP
Pulled the motor on my 2.8 Monty SWB today. She started loosing power and the other day wouldn't start. Ran a compression check and had 40 lbs on #1 and 0lbs on #2. I think the timing might of jumped. It looks like the fuel pump gasket was leaking oil and the head gasket as well. I haven't got it on the motor stand yet and haven't pulled the head to see what it looks like. Anyway, on E-bay AAAA Automotive it selling G54B 2.8's for $480.00 rebuilt. They list them for 1981 - 1984 monty's. If things look bad will this engine work with my 1988 with 5 speed or do you think I should redo the head and reinstall? I would like to swap in the turbo or a GM 6, but don't have the time to do it right now.
Thanks, Nate <img src="/forums/images/graemlins/confused.gif" alt="" />
1988 2DR 5SP 2.6l Monty. Balance shaft elimination kit installed. 120k miles. Timing jumped, pulling motor to see what needs to be done.
Re: Will a 84 G54B 2.8 fit in a 88? [Re: billygoat] #856657 01/02/08 08:24 AM
cjsmontero Offline
The g54b is a 2.6 isnt it? This is a good start I think
http://www.4x4wire.com/forums/showf...mp;amp;sb=5&o=14&fpart=1
Last time I did this I sent the guy with a 6cyl question to the 4cyl link! Hope I helped a bit.
cjm <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Will a 84 G54B 2.8 fit in a 88? [Re: cjsmontero] #856658 01/02/08 02:56 PM
Yes, it is a 2.6. I goofed up and put 2.8. I had just got done listing my Ford Windstar with a 3.8 with a bad trans for parts and the 8 was stuck in my head. Anyway, I was wondering if the older 84 2.6 would fit my 88. I will go measure the bell housing ans see what I get.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5906 MB (Peak: 0.6451 MB) Data Comp: Off Server Time: 2026-06-12 23:48:53 UTC
