intake manifold torque specs 99 rodeo lse 3.2v6 #856868 01/02/08 08:02 PM
trentch Offline OP
the haynes manual states 17lbs torque on the lower intake, does anyone have any updates on this tourqe spec as well as the plenum? i'm about to start the gasket replacement process. Thank's!
99 rodeo lse
Re: intake manifold torque specs 99 rodeo lse 3.2v6 [Re: trentch] #856869 01/03/08 01:16 AM
boritz Offline
G'day,
Yes, Isuzu manual says 18 lb-ft for all intake manifold bolts (near enough to your 17).
62Mb PDF workshop manual download for the V6 http://www.spottedhaggis.com/isuzu/090.pdf
It's for the Trooper but the engine/trans sections are applicable.
Aussie 1997 3.2V6 SOHC 6VD1 Holden Jackaroo SE (Isuzu Trooper/Bighorn/Monterey) 5-speed manual, rear LSD, front Lokka (manual free-wheel hubs).
Re: intake manifold torque specs 99 rodeo lse 3.2v6 [Re: boritz] #856870 01/03/08 02:24 AM
Gizzy42 Offline
13 ft lbs. Isuzu revised it a while ago. There is a TSB about it but I dont remember which one at the moment. Make sure you use an inch lb wrench as a ft lb torque wrench wont be accurate enough at that low of a setting.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO on US Wheel 94 series
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 50 series SUV 2.25"
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Re: intake manifold torque specs 99 rodeo lse 3.2v6 [Re: Gizzy42] #856871 01/03/08 02:43 AM
mlclark Offline
Isuzu Moderator
Just for clarification, what is it. lb-ft or lb-in?
13lb-ft is 156lb-in. I think most lb-in wrenches can do that, but low range lb-ft wrenches are out there too.
Just don't put 13lb-ft on a 13lb-in bolt. Actually, you won't get there. It will break long before you get that tight. <img src="/forums/images/graemlins/smile.gif" alt="" />
Good Luck,
Michael
Re: intake manifold torque specs 99 rodeo lse 3.2v6 [Re: mlclark] #856872 01/03/08 03:57 AM
Gizzy42 Offline
Its ft lbs. I always recommend converting to inch lbs and using an inch lb wrench at that low of a setting for accuracy and most ppl dont have low range ft lb wrenches.
--Dave
Rear No-Slip Locker
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6067 MB (Peak: 0.6713 MB) Data Comp: Off Server Time: 2026-06-16 08:32:35 UTC
