Temp gauge on 87' 22RE #856987 01/03/08 01:21 AM
W
wheelin34m Offline OP
When my son starts his truck, he says the temp gauge instantly goes up about halfway and stays there for a few minutes...then drops to cold, then bounces back up to halfway...I think the gauge itself must be bad...is there anyway to test it?...the truck does not over-heat
thanks for any help
Re: Temp gauge on 87' 22RE [Re: wheelin34m] #856988 01/03/08 03:26 AM
dcg9381 Offline
That behavior is typical of these "dampened" gauges.
I believe there is a test procedure - maybe an ohm spec in the factory service manual.
I may have a spare if you want one, depending on which cluster you have, but my suggestion is to live with it as a toyota-ism...
22REturbo.net
1988 4Runner
Re: Temp gauge on 87' 22RE [Re: dcg9381] #856989 01/03/08 03:54 AM
yota4runna Offline
Yep. My temp gauges do this, too. Not a problem.
Re: Temp gauge on 87' 22RE [Re: yota4runna] #856990 01/03/08 12:58 PM
DRTDEVL Offline
All of our '87's do it...
Get an aftermarket gauge and plumb it into the block drain (lower driver's side of the engine block).
Re: Temp gauge on 87' 22RE [Re: wheelin34m] #856991 01/04/08 07:39 PM
VanillaTHUNDA Offline
I've found that If I punch/hit the cluster when the gauge pegs it'll go back to normal! Probably won't continue to do that for long, though.
I recall seeing a thread on this where somebody FINALLY fixed the problem- whoever it was put claw washers on the ground screws on the back of the clusters and torqued the hell out of them, digging the washer into the metal. Worth a shot...
Re: Temp gauge on 87' 22RE [Re: VanillaTHUNDA] #856992 01/04/08 08:23 PM
DRTDEVL Offline
Yeah... I followed that closely. It worked for about a month, then quit again.
Re: Temp gauge on 87' 22RE [Re: wheelin34m] #856993 01/15/08 08:03 AM
Chunky Offline
My 87 temp gauge stabbed me in the back. The damn thing got stuck at normal temp when one of the aux. coolant hoses busted. I don't know how long I was driving with an over temped engine, but when I finally noticed smoke I flicked the dash and the gauge swung up to "melt down" level. A long tow and one head gasket later I was back on road. But I'll never trust that gauge again.
'87 4Runner
Re: Temp gauge on 87' 22RE [Re: Chunky] #856994 01/16/08 03:26 AM
lethe Offline
mines never done that before <img src="/forums/images/graemlins/confused.gif" alt="" /> maybe im just lucky.
87' ext cab toy
Re: Temp gauge on 87' 22RE [Re: Chunky] #856995 01/16/08 09:14 PM
Yeah, I've had that happen to me at one point- fortunately I caught it before any real damage was done. I pulled off and opened the hood to see my exhaust manifold cherry red- scary stuff!
PHP: 7.4.33 Page Time: 1.397s Queries: 15 (1.394s) Memory: 0.6238 MB (Peak: 0.7267 MB) Data Comp: Off Server Time: 2026-10-24 22:07:29 UTC
