Re: how many mile on your montero or mighty max
[Re: 93montero_sr]
#857281
01/09/08 04:30 PM
About 118k on my '94 LS. I hope I can extrapolate that to mean it will be 236k in 2022 <img src="/forums/images/graemlins/kewl.gif" alt="" />
Jim
1994 Montero LS
[Re: StockRaider]
#857282
01/10/08 02:50 AM
I rolled the Montero over to 173k about 600 miles/ 3 days ago... Raider has about 178 on the odo as she sits. <img src="/forums/images/graemlins/kewl.gif" alt="" /> Damn, you haven't wasted time giving that old pup a workout once again <img src="/forums/images/graemlins/smile.gif" alt="" /> It wasn't long ago she was doing the 800 mile weekend trips to connecticut.
1999 Mitsu Montero - Crappy Weather 1992 Isuzu Pickup - Zombie Apocalypse 2008 Saturn Sky Redline - Nice Weather
[Re: 87Montero]
#857283
01/10/08 03:43 AM
Yea, it's getting up there. Don't do anything special - the spark plugs and wires haven't been changed in five years.:-) Mobil 1 10-30 full synthetic (green cap) in the engine. The big Mitsu oil filter from Carquest. BG MOA every oil change. I change oil every 8-9k. Clean the air filter about once a year. Amsoil synthetic in the trans and t-case. I was running redline in the diffs but I switched the front to Amsoil when I installed the new ARB diff cover last month and I'll do the back when the weather warms up. $9 a quart Amsoil vs. $20 a quart Redline. Mmmmm. Hard choice.:-)
87Montero:
That's what I was trying to figure out a couple days ago. The SAS was finished beginning of May 2001 and I think I had about 115K on my Sport when the conversion was done. Have to check but I know that's real close 'cause I'd just had my first timing belt replacment the year before and I was a bit overdue on that. So, most of the miliage is on the SAS.
Had to replace a rear shock that got hit with a log or something the year before last; one of the stupid Ford spring pads (cracked); I've changed out all the tie-rod ends twice and the track bar bushing four or five times. Oh, and three Heim joints - until I found out that the idiots at the speed shop I was buying from was selling me the cheap joints and charging me for the good ones. Grrr!!! Haven't broken one of those in a couple years now. And, I finally had to replace the original front axle u-joints last fall. Innumerable rear diff u-joints - 'cause I guess I still don't kwow where my rear diff is in relation to the GIANT ROCK I just drove over.:-( OH, and I switched to the Powerslot rotors and Hawk pads all the way around; they brake better and look like they'll last longer than the Napa rotors and pads I was using.
Only thing I've ever broken (keeping fingers crossed) 'wheeling was the Heim joint on my track bar and that was because there wasn't enough clearance around the Heim joint after the suspension was broke in. Fixed that with a Rotozip and a grider wheel several years ago. Figure if I didn't break it on Flat Pass Road June before last it's good.:-)
And, I'm on my third or fourth set of leaf springs - axle wrap from the spring-over, WAY overloaded vehicle, deeper t-case gears and the super sticky sandstone in Moab. The new set is completely redesigned with torque leafs and a different rate. Keeping fingers crossed with these as well.:-) Managed to bust both the left and right side primary leaves on Elephant Hill in November. Made for an interesting drive back to Denver.:-(
Anyway, can't imagine how much Mitsu replacement parts would have cost in that time if I would have stuck with the IFS.
'97 Montero Sport LS 5-Speed 3.5L conversion SAS Dana 44s & ARBs, 35" Yoko Geolandar M/Ts NP231 B4R doubler/Terra Low231/RP 5.38 229:1 '99 Montero Sport Limited 4WD SAS 3-link project '03 Montero Sport Limited AWD '97 Montero Sport LS 5-Speed 4WD
[Re: 93montero_sr]
#857284
01/10/08 04:33 AM
1989 3.0 never rebuilt, pushing 210,000. Gonna need a new clutch and valve seals soon, and I'm wondering why my mileage has suddenly taken a nose-dive <img src="/forums/images/graemlins/confused.gif" alt="" />
Eric W.
[Re: 89IsMine]
#857285
01/10/08 04:54 AM
88 2.6 117k 3rd owner. Bought it from my uncle and his real estate agent had it before him. May of been in 4wd 5 times before I got my hands on it. Put a new Mikuni on at about 90k when I purchased it. Also had a seized spark plug in the head. It came out with minium damage. Still running like a top.
[Re: 87Montero]
#857286
01/10/08 03:19 PM
I rolled the Montero over to 173k about 600 miles/ 3 days ago... Raider has about 178 on the odo as she sits. <img src="/forums/images/graemlins/kewl.gif" alt="" /> Damn, you haven't wasted time giving that old pup a workout once again <img src="/forums/images/graemlins/smile.gif" alt="" /> It wasn't long ago she was doing the 800 mile weekend trips to connecticut. She handles tbe trips like a champ. Ball joints are shot though so it makes for interesting times. MPG is also sh*t at 13.5 mpg with cruise set at 70 <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> I assume the balljoints cant help and the fact the fill and vent hoses on the gas tank are shot. I am a little concerned with the mpg figures but I will get to that bridge when I get the Raider working again. Hate to drag this off track but this weekend is tear into time (woot!) <img src="/forums/images/graemlins/lol.gif" alt="" />
Richard E 1989 Montero - Stock-ish 1989 V6 Auto Raider - 5.3 Vortech Swap. 1987 Mitsubishi Starion 2.6t, soon to be 3.5 1983 Honda XL600R
[Re: 93montero_sr]
#857287
01/10/08 03:31 PM
204k and counting. <img src="/forums/images/graemlins/kewl.gif" alt="" /> I just amended my profile to reflect this. I've only owned the Montero since Jan. 2003, it had about 152K on it then.
'92 SR Montero, Green, with 31" Yokohama Geolandar A/T Plus Tires, Mitsu factory fog light kit, on-board air compressor,Sony Radio and 10 disc changer. 213K and counting..... Stock & Happy otherwise
[Re: 93montero_sr]
#857288
03/04/08 08:24 AM
2 months later and i racked an extra 132 miles bringing the grand total to 152,664, i guess i should drive it a little more. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
93 montero sr 3 inch body lift 31x11.50 super swamper ltb, 2 8inch 130 watt pro comp off road lights, 2 55w lights on the rear bumper, rear air locker, magnaflow exhaust muffler,superwinch manual hubs,15x8 black rock crawlers (steel)
[Re: 93montero_sr]
#857289
03/05/08 05:09 AM
93montero_sr yours has low miles most of the 93 here in az have 250 or more miles on them. My 89 has 173k and has been hanging out in my garage waiting for me to finish its sas.
89 2 dr turbo diesel 89/88 "Backwoods sas"
[Re: LAMONTEROGUY]
#857290
03/05/08 11:15 AM
89 3.0L, 262K and driving daily thanks to the help from this forum to find my starting problem.
89 3.0 LWB Montero, 1st Gen, 5 Speed Manual, 5 Door
