dual carb 2.6 mani
#858799
01/09/08 09:30 PM
A dual carb mani for the 2.6. Can you say "injector bosses" and "MPI"? Edit: Another source: Aussies?
Re: dual carb 2.6 mani
[Re: fasteddy]
#858800
01/09/08 10:43 PM
I wonder if you could rig it to be able to shut one down on the fly for better mileage and on again when that extra oomf is needed. Seems kinda cool.
?_________ |_|_|\____\___ l-----[O]≡≡≡≡[O] ()_)()_)-----)_) Stay the Trail!
[Re: CapnCrunch]
#858801
01/10/08 02:14 AM
It won't work that way. Each cylinder is fed by one barrel of one carb, with no interconnection. It's a nice way to work it, but brake vac may suffer some, and the sidedraft carbs may not clear the brake booster. I think KevinC has/had one like this...
[Re: fasteddy]
#858802
01/10/08 04:07 AM
Suuure eddy, one feedback carb aint enough...you need two of 'um
I got a 100 ft. roll of heavy duty thick wall vac hose from a garage close-out the other day. Might be enough...
1989 5 door montero 3.0 auto stock original Japanese about 200k miles
[Re: generation_one]
#858803
01/10/08 04:41 AM
If I buy one, no carbs for me. Bolt on runners/plenum/TB and weld on injector bungs and you have an FI manifold, needing only a megasquirt and some tuning.
If I did carb it, I'd think long and hard about 4 90* bends and a pair of Weber 44idf's. The mani is flanged for Weber DCOE's and anything like Solex sidedrafts that bolt to the same pattern.
[Re: fasteddy]
#858804
01/10/08 05:49 AM
that sounds better you can make a kit for sale
"oriental eddy's cusstem fuyl sistum injun ear-ring, Inc."
[Re: fasteddy]
#858805
01/10/08 02:15 PM
If you buy that style manifold the TBs come with injector bosses in them. Another option might be something like this per chance? ![[Linked Image]](http://www.vermontel.net/~dcma/W3020025.JPG)
[Re: OldColt]
#858806
01/10/08 03:08 PM
That should be in the Louvre. Its a work of Art <img src="/forums/images/graemlins/drunk.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
'88 Raider 2.6L - SW Hubs, Weber 32/36, Off-road Pkg - Dead '88 Monty 2.7L - 5" Lift, Weber 38, 33's, Dual Fans, Dual bouncy (more goodies to install) - Still Kicking. '03 Monty Sport - XLS, BFG A/T's - Dead
[Re: shadowgear]
#858807
01/10/08 03:57 PM
Impressive looking, no doubt. But I don't see those horns doing any river crossings. <img src="/forums/images/graemlins/lol.gif" alt="" />
[Re: MontyMcV]
#858808
01/10/08 04:51 PM
Hah! Maybe with those horns you have enough power to do 90mph Icelandic river crossings, where all that hits the water are the madly spinning supertires...
Yeah, I saw the ITB manifold option on the same website with the bungs, but bungs and welding are cheaper.
That is a nice piece of work, Charlie. I like the velocity stacks. I think if I ever get an MPI manifold built, I'll use some like that in the plenum. I hear you get a strong diff in airflow capacity from smoothing the inlet flow into the runners.
