Re-torque after rebuild #859032 01/10/08 06:10 PM
Stevie Offline OP
Just my experience:
After about 500 miles, I found the two front cylinder head bolts loose. Also, some of the exhaust bolts needed tightening as well. A couple valves were a little loose too. Was time well spent.
'80 4X4 Longbed
Re: Re-torque after rebuild [Re: Stevie] #859033 01/10/08 08:57 PM
missouriman Offline
X 100
yes, it sucks to take your new motor back down.
yes, it is worth the whole cost of the build to do it.
Yes, it will make a huge difference.
Yes, I am glad that some one else thinks the same way I do.
priceless
edit.
making sure that the head bolts dont have crap in the bottom. lenth of like water pump bolts.
check and re check everything. then 500 miles or I do it after warm up. 100, and 500 miles.
I have not had alot of the problems that I read about here and on other sites.
I am not sure how the factory gets this done....
I mean that a rebuild never lasts as long as factory.. after market, (starters, alt, trans, clutch, u- joints) don't seem to last as long as the factory ones do.. Not sure what to make of that....
but I will take a junk yard (say alt, or starter) over a rebuild any time.
any input on this? it would seem that with the rebuilds they would know the weak spot and fix it..
Re: Re-torque after rebuild [Re: missouriman] #859034 01/10/08 10:20 PM
Bolosh Offline
I pity the fool who don't do a retorque after a rebuild!! Uuuurrrggghhhh! <img src="/forums/images/graemlins/mrt.gif" alt="" />
I didn't know about that when I rebuilt mine <img src="/forums/images/graemlins/frown.gif" alt="" /> Basically had to do it all over again.
Re: Re-torque after rebuild [Re: Bolosh] #859035 01/10/08 11:49 PM
dcg9381 Offline
In my experience, you really need to check everything after 500-1k miles. The head bolts are most critical, but everything will need to be retorqued - front cover, oil pan, intake manifold, exhaust manifold...
22REturbo.net
1988 4Runner
Re: Re-torque after rebuild [Re: dcg9381] #859036 01/11/08 04:38 AM
O
outdoorfan Offline
I don't know how a person would even get to some of those intake manifold bolts when everything's hooked up?
Re: Re-torque after rebuild [Re: outdoorfan] #859037 01/11/08 04:41 AM
kewlynx Offline
Swivels, baby. <img src="/forums/images/graemlins/baby.gif" alt="" />
**ubi apis- ibi salus**
Re: Re-torque after rebuild [Re: kewlynx] #859038 01/11/08 05:28 AM
Vanishing_Point Offline
2x
Re: Re-torque after rebuild [Re: kewlynx] #859039 01/11/08 05:34 PM
engnbldr Offline
>>>*Yea, without swivels, guys the size of me don't work on cars at all....*LOL**..
I will stick my poor opinion in here also, for what it is worth. When using new fastners, retorque is even more important than when reinstalling the old ones.
Either way, heating and cooling cycles cause metal molecules to move, and they can lose clamping force.
Kudos to the O/P, a good tip and we see the same regularly. Best to take the time to recheck, it can save the job down the road....*EB
*Beats the he** outa me!....*LOL**...
Re: Re-torque after rebuild [Re: engnbldr] #859040 01/11/08 06:10 PM
yota4runna Offline
When using new fastners, retorque is even more important than when reinstalling the old ones....*EB
So, how do the factories send out millions of vehicles that run hundreds of thousands of miles without retorquing?
Re: Re-torque after rebuild [Re: yota4runna] #859041 01/11/08 07:01 PM
Bogo Offline
Tolerance analysis and experience. Between the two of them you can figure out exactly how much you need to torque a bolt of known properties and how much it will loosen over time.
-- Bryan
PHP: 7.4.33 Page Time: 2.769s Queries: 16 (0.004s) Memory: 0.6432 MB (Peak: 0.7639 MB) Data Comp: Off Server Time: 2026-05-30 04:30:07 UTC
