2001 Kia Sportage will not start
#859613
01/13/08 07:44 PM
I have checked and replaced almost everything and still nothing. I'm thinking it might be the computer or the cam sensor. Anyone out there that has had this problem? I can't even buy a manual, the auto parts store can't get one.
Re: 2001 Kia Sportage will not start
[Re: brownt]
#859614
01/13/08 10:06 PM
Kia Moderator Emeritus
Does the engine crank at a much higher speed than normal yet fail to start? If yes the timing belt is broken.
But even if it cranks normal I would still check it. It might have jumped a cog or two but not break. Remove the screws from the upper timing belt cover and carefully pry it back and check to see if the belt is OK.
1998 Sportage - Gone. 2004 Honda Civic Coupe. 2007 Suzuki Grand Vitara - She got it.
[Re: brownt]
#859615
01/14/08 05:10 AM
I can't even buy a manual, the auto parts store can't get one. You can access the factory service manual online: http://www.kiatechinfo.com/index.asp You'll have to register and log in. I seem to remember having trouble viewing certain pages unless answered every question about how my Sporty was equipped. Good Luck, ks
'99 Sportage 4dr EX 5-speed, unmolested '98 Sportage 4dr Auto 2wd '96 Sportage 4dr Auto,235-75x29"tires, custom fabbed hidden receiver hitch and big plans.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5919 MB (Peak: 0.6449 MB) Data Comp: Off Server Time: 2026-10-28 04:04:21 UTCValid HTML 5 and Valid CSS
