Help Blinker Fuse keeps blowing?
#859626
01/13/08 08:36 PM
Hi the blinkers on my 98 T keeps blowing the fuse. I have replaced the bulbs and checked the wires to no avail. It is only one side, if you turn on the right its is ok. As soon as you turn on the left, it blinks once and dims and the fuse blows. Any ideas?? <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Help Blinker Fuse keeps blowing?
[Re: hester1]
#859627
01/14/08 02:50 AM
Sounds like a short to ground!
97 T100 4x4 97 328i 95 540i restoration project
[Re: eleet]
#859628
01/14/08 03:28 AM
x2. Disconnect one left light assembly at a time. If after disconnecting both of them and still blowing fuses, work your way forward in the harness to find your culprit.
You haven't taken any hits on those left corners, have you? Sometimes if you get a fender bender, it'll do some wiring damage too.
[Re: hester1]
#859629
01/14/08 04:02 AM
Don't forget to check the trailer wiring too (if equipped).
[Re: Alluvial_Plains]
#859630
01/14/08 04:08 PM
Good point, there is trailer wiring. Can that affect the blinkers?
[Re: hester1]
#859631
01/14/08 06:17 PM
Yes - especially if the box (converter) is shorted.
[Re: hester1]
#859632
01/14/08 07:12 PM
The most common probs with the lights come from the trailer converter box. <img src="/forums/images/graemlins/wink.gif" alt="" />
[Re: BamZipPow]
#859633
01/14/08 07:26 PM
Is there a way to check or fix this?
[Re: hester1]
#859634
01/14/08 08:19 PM
Disconnect it at the quick connects on the drivers side by the tail light. I went through this last winter and ended up just taking the whole crappy crimped on connector mess off and soldered in new leads for a replacement though if someone knows a good spot to buy a new converter that would be nice.
1997 T-100 100k and counting Green 5spd 4x4 Ext Cab isr mod Aisin Manual hubs
[Re: Flannelman]
#859635
01/14/08 08:47 PM
Ok Thanks! <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6368 MB (Peak: 0.7430 MB) Data Comp: Off Server Time: 2026-05-29 22:12:04 UTCValid HTML 5 and Valid CSS
