Help Blinker Fuse keeps blowing? #859626 01/13/08 08:36 PM
hester1 Offline OP
Hi the blinkers on my 98 T keeps blowing the fuse. I have replaced the bulbs and checked the wires to no avail. It is only one side, if you turn on the right its is ok. As soon as you turn on the left, it blinks once and dims and the fuse blows. Any ideas?? <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Help Blinker Fuse keeps blowing? [Re: hester1] #859627 01/14/08 02:50 AM
E
eleet Offline
Sounds like a short to ground!
97 T100 4x4
97 328i
95 540i restoration project
Re: Help Blinker Fuse keeps blowing? [Re: eleet] #859628 01/14/08 03:28 AM
kewlynx Offline
x2. Disconnect one left light assembly at a time. If after disconnecting both of them and still blowing fuses, work your way forward in the harness to find your culprit.
You haven't taken any hits on those left corners, have you? Sometimes if you get a fender bender, it'll do some wiring damage too.
**ubi apis- ibi salus**
Re: Help Blinker Fuse keeps blowing? [Re: hester1] #859629 01/14/08 04:02 AM
A
Alluvial_Plains Offline
Don't forget to check the trailer wiring too (if equipped).
Re: Help Blinker Fuse keeps blowing? [Re: Alluvial_Plains] #859630 01/14/08 04:08 PM
hester1 Offline OP
Good point, there is trailer wiring. Can that affect the blinkers?
Re: Help Blinker Fuse keeps blowing? [Re: hester1] #859631 01/14/08 06:17 PM
A
Yes - especially if the box (converter) is shorted.
Re: Help Blinker Fuse keeps blowing? [Re: hester1] #859632 01/14/08 07:12 PM
BamZipPow Offline
The most common probs with the lights come from the trailer converter box. <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: Help Blinker Fuse keeps blowing? [Re: BamZipPow] #859633 01/14/08 07:26 PM
hester1 Offline OP
Is there a way to check or fix this?
Re: Help Blinker Fuse keeps blowing? [Re: hester1] #859634 01/14/08 08:19 PM
F
Flannelman Offline
Disconnect it at the quick connects on the drivers side by the tail light. I went through this last winter and ended up just taking the whole crappy crimped on connector mess off and soldered in new leads for a replacement though if someone knows a good spot to buy a new converter that would be nice.
1997 T-100 100k and counting Green
5spd 4x4 Ext Cab isr mod Aisin Manual hubs
Re: Help Blinker Fuse keeps blowing? [Re: Flannelman] #859635 01/14/08 08:47 PM
hester1 Offline OP
Ok Thanks! <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6335 MB (Peak: 0.7397 MB) Data Comp: Off Server Time: 2026-05-26 13:35:46 UTC
