Page 2 of 7 1 2 3 4 5 6 7
Re: half way there on the front lift [Re: jaybur] #859897 01/15/08 07:03 PM
blitz Offline
looks good..i think the front wheel wells might be a little higher and give the illusion of rear being lower.measure from the ground to frame and it might be about the same front and rear.i like the baja look anyway. i dont think the tires look too small.thats the same size im runnin.i would like a little bigger but that size is a good compromise between power loss,and extra lift. nice work man <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: half way there on the front lift [Re: blitz] #859898 01/15/08 07:35 PM
jaybur Offline OP
thanks, yea I think it is slightly different in the wheel wells too. And I don't think the tires are too small. I think the gearing is better now than stock, in the future I may run 31's but I think that the biggest I'd go. I'll wear my tires down before I switch sizes.
I did like my other wheels though, they were 8.5" wide, the chrome ones are 7" wide. I didn't realize that until I bought 2 spare tires for $50, had them mounted up and the guy was like, you know you have 2 different size wheels?
they stick out a bit more with the 8.5's.
Sportage sold.........
1999 4runner 4x4 , Tundra brake rotors and calipers (well worth it!) -wifes
Re: half way there on the front lift [Re: blitz] #859899 01/15/08 07:37 PM
jaybur Offline OP
what are you running for lift? I see some spacers in there so I would assume the eibachs.
Re: half way there on the front lift [Re: jaybur] #859900 01/15/08 08:32 PM
blitz Offline
yea eibachs with the dennis spacers. ive heard the rears sag after awhile but i havent noticed it yet.
Re: half way there on the front lift [Re: jaybur] #859901 01/15/08 08:39 PM
Dave Scott Offline
I think the ride is a little stiffer, but totally acceptable. the rear is lower, but hardly noticeable my driveway is a little deceiving as it slants away from the house (good thing!)
thanks! <img src="/forums/images/graemlins/kewl.gif" alt="" />
well, i can get the coils made a little softer, i've just never heard of any issues with the stiffness, other than that people preferred it stiffer. they ARE stiffer than the Eibachs, i did that on purpose because i knew they'd be taller, allow more travel and didn't want them to squish too far when cornering and that sorta thing, however, they still flex as far as they can off the road.
sorry for the hijack, but if anyone else has constructive criticism (for those that have my products) lemme know via pm or something. thanks...
Re: half way there on the front lift [Re: Dave Scott] #859902 01/15/08 09:15 PM
jaybur Offline OP
I wouldn't change them. Just stating that they are a little stiffer than stock, not a bad thing, I think its a good thing.
I am happy with them dave..... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: half way there on the front lift [Re: jaybur] #859903 01/15/08 09:41 PM
Dave Scott Offline
cool. i didn't think you were complaining, i just like the feedback, i don't seem to get much.
Re: half way there on the front lift [Re: jaybur] #859904 01/15/08 09:45 PM
Nukeiridium Offline
Please don't make mine any softer Dave! <img src="/forums/images/graemlins/scared.gif" alt="" />
Jaybur - So you have Dave's springs up front, and TJ springs in the rear right?
Which lifts the rear more, Dave's RSG springs or the TJ springs?
I have the TJ springs already, and ordered the RSG kit, if the RSG rear lift is not any taller than your setup for the rear, then I may want to switch to Mazda MPV springs, I like the rear a bit taller than the front. Especially since the rear will ride lower when loaded with stuff for a trip.
Overall, your results look awesome, I'm excited to do mine! I bet you are excited to get it on there <img src="/forums/images/graemlins/smile.gif" alt="" />
2002 Sportage 4dr 4x4 soon to undergo an Extreme Makeover!
Re: half way there on the front lift [Re: Nukeiridium] #859905 01/15/08 10:03 PM
Nukeiridium Offline
Jaybur are those 30" tires you are running now?
This probably will draw some jeers, but I actually don't think the car drives very well on 31's. I remember 30" tires were fine, but the difference when I went up 1 more inch was very noticeable, it was much harder to get going off the line.
Besides, how much difference do the 31's make over 30's when you are aired down on the trail? I wonder... I never had trouble with 30's, I dunno how much difference the 31's made. I think for drivability, 30's are the best compromise.. Just my 2 cents.
Re: half way there on the front lift [Re: Nukeiridium] #859906 01/15/08 10:14 PM
Dave Scott Offline
the rear actually comes out a little higher than the front. the rear springs are also a little stiffer than the Eibachs which are a little stiffer than stock so they should be able to handle a load pretty well, but no feedback on that yet either. you used the MPV coils before, didn't you? how'd they ride? how'd they flex, what was the diameter? any pics? etc. the TJ coils supposedly deliver between 3.5 and 4" of lift and the RSG coils are around 4.25-4.5". the Aerostar coils would deliver between 5 and 6" and are a nice ride and are made so that the first 2-3 inches compress easily and then quickly tighten up thereafter.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6477 MB (Peak: 0.7567 MB) Data Comp: Off Server Time: 2026-06-10 01:46:36 UTC
