Page 2 of 3 1 2 3
Re: Tires... [Re: Nick_] #860003 01/16/08 09:58 AM
CapnCrunch Offline
leading edges of the fenderwell insides were trimmed.
This was what i was questioning, i already plan on taking my bumper stops off so i'm not worried about that. But the fenderwells? Like the lower end of the fender? Near the bumpstop on the front i assume?
How much should i take off, or do you think it would be fine if i drove my SUV home and then trimmed em once the tires were on?
I'm pretty sure he's talking about the splash shield that's at the very front of both front wheelwells, right squarely in front of the front tires. It's a little shield that sticks down. I just pushed mine forward with my hand and they were go to go. You can put the tires on and drive around before doing that. I didn't notice that this needed to be done on mine until I was in the midst of doing a trail and was under heavy flex.
Edit: What exactly is different from the 4cyl to v6 brakes?
Basically, here's the differences between your's (an 87) and later front brakes:
rotor diameter
87 - 10"
89-91 V6 - 10.9"
calipers
87 - V-groove slider
88-91 - pin-type slider
caliper brackets
larger on the 89-91 V6 to accommodate the bigger rotors
rotor dust shields
V6 brake booster and master cylinder gives more volume and pressure
For reference see:
http://www.geocities.com/spun_bearing/brakes
EDIT:
And I can only get it from a junkyard, or a parted out vehicle right?
The booster/master cylinder, brackets, and dust shields are best found at a junkyard. I don't know if you can get those new (or want to pay the price if new). The calipers and rotors can be gotten new from many places. I've gotten them from Pep Boys and NAPA. You would likely have a core charge for the calipers, so if you can grab those for just a couple bucks off a junkyard rig it might be worth it.
?_________
|_|_|\____\___
l-----[O]≡≡≡≡[O]
()_)()_)-----)_)
Stay the Trail!
Re: Tires... [Re: CapnCrunch] #860004 01/16/08 07:56 PM
N
Nick_ Offline OP
rotor diameter
87 - 10"
89-91 V6 - 10.9"
calipers
caliper brackets
rotor dust shields
For reference see:
EDIT:
Thanks for all the info! Yea, I may just try and find them at a junkyard. But, i did some searching...
http://cpwstore.carpartswholesale.com/catalog/?N=10179+1607+4294966998+9177
http://cpwstore.carpartswholesale.com/catalog/?Ne=28&N=10179+1607+4294966998+9178
http://cpwstore.carpartswholesale.com/catalog/?Ne=28&N=10179+1607+4294966998+9179
http://cpwstore.carpartswholesale.com/catalog/?Ne=28&N=10179+1607+4294966998+9180
http://cpwstore.carpartswholesale.com/catalog/?Ne=28&N=10179+1607+4294966998+9181
http://cpwstore.carpartswholesale.com/catalog/?Ne=28&N=10179+1607+4294966998+9182
I essentually get anything that fits "89 6 Cyl Base"? The price for all of that really isn't bad (350ish), i'd probably consider doing that.
Do you think that may be a good idea?
87 Dodge Raider 2.6l KYB Shocks, 35 BFG Mud Terrains!
3 Inch Body Lift
Custom front and rear bumpers
Roof Rack
Coming soon!
Re: Tires... [Re: Nick_] #860005 01/16/08 08:10 PM
DRaider90 Offline
If you have the money and are ready to spend it go for it. You will also be getting parts in better shape (usually at least).
88 Raider(Red):160k-Reman'd 2.6-5spd-Weber-SW Hubs-34x9.5 TSL-OffRd Pkg-1"Tbar-2"BL-CB
88 Raider(Silver):No 2.6/Bad KM145 Parts/Project
88 Montero(Brown):No 2.6,4.88s Parts/Project
[b]4X4 STICKERS,SHIRTS,ETC:
4WD Stickers AT COST.[b]
Re: Tires... [Re: DRaider90] #860006 01/16/08 08:22 PM
N
Nick_ Offline OP
Yea, with a new motor put in it, and nearly everything mechanical besides the carb replaced. I feel that maybe just going newer, i will have a better life span on most things.
A 1989 monty in a junkyard collecting rust on everything and paying a good chunk of money for all the parts if i am lucky to even find them doesn't sound like the greatest idea in a few years. XD
3 Inch Body Lift
Roof Rack
Coming soon!
Re: Tires... [Re: Nick_] #860007 01/16/08 08:36 PM
jerzboy Offline
I thought the front bumper looked better with just the middle section left, so i removed them completely. this is the final result (i think it looks good, but it's a completely ineffective bumper for front corner protection):
'09 Acura TSX Tech Package
'05 Blazer (Company hauler)
Retired '88 Bada$$ edition Raider (now owned by shadowgear)
Re: Tires... [Re: Nick_] #860008 01/16/08 08:41 PM
DirtDriver Offline
Oh and don't worry, my girlfriend likes when i drive a bit scary. <img src="/forums/images/graemlins/shiner.gif" alt="" />
Now I'm worried. <img src="/forums/images/graemlins/lol.gif" alt="" />
I wouldn't write off the junkyard option. Trucks don't spend that much time in junkyards before they're crushed for scrap. Sure they're sitting outside in the few weeks/months they're there, but most people keep they're vehicles outside anyway, so what's the diff? Couple of advantages IMHO. One, you get extra practice--removing the components from the junkyard truck, and then again on removing your old junk. Of course, this only applies to pick-n-pull yards, as opposed to the ones where they pull it. Two, I'd bet you'd get it for half the price. If you decide to go that way, just visit the yards until you find a nice clean one. Shouldn't take long, V6's pop up all the time.
1990 Monty LS 3.0 A/T LWB. KYB front shocks, OME rears and coils. 33x10.5 BFG Muds. 5.29, 2.85, RD110, RD46. 2 bouncys. Aisins. Monte Disco swaybar disconnects. GenII t-arms, idler arm, UCA's, V45W front brakes. 2in BL.
Re: Tires... [Re: DirtDriver] #860009 01/16/08 08:50 PM
CapnCrunch Offline
Ditto. I've gotten LOTS of parts from the junkyard, and I put them through some serious punishment. Most are good for re-use. And those that aren't can sometimes be used for core-returns if the price is right.
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: Tires... [Re: CapnCrunch] #860010 01/17/08 06:17 AM
Chris_J Offline
under heavy flex
Whats that? 1-2 inchs? <img src="/forums/images/graemlins/lol.gif" alt="" /> with our wonderful IFS <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: Tires... [Re: Chris_J] #860011 01/17/08 07:44 AM
CapnCrunch Offline
under heavy flex
I get a lot more flex than that with mine. So much so that every time I have gone wheeling with Jeep drivers over the last year or so, they all comment on how much flex I have given that I have IFS. One of these days I'll have to measure it. No, it doesn't flex as much as a solid axle front end, but it's more than your standard unmodified Gen I.
Bear in mind that I don't have a swaybar installed and I've made some modifications to my front suspension.
But even back before that, I still had some flex up front.
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: Tires... [Re: CapnCrunch] #860012 01/17/08 06:37 PM
Chris_J Offline
Yea. Its not to bad. After we put the rear locker in went to try it out on a loading dock backed it up and stuffed a front tire and started lifting the other <img src="/forums/images/graemlins/zombie.gif" alt="" /> . Not a good feeling on concrete or behind Staples <img src="/forums/images/graemlins/lol.gif" alt="" />
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6530 MB (Peak: 0.7738 MB) Data Comp: Off Server Time: 2026-06-23 00:43:10 UTC
