tick...tick...tick...tap....tap...tap...TAP..TAP..TAP......VLA help #860955 01/18/08 05:52 PM
Steve Nichols Offline OP
IÆve been having problems with lash adjuster tick/tap.
The truck was stood for 3 months, but is now back on the road, but I have a tick/tap. On cold start there is the usual (for my truck) tick which goes away very quickly. After about 2 minÆs it comes back, then gets louder, sounds like a bag of loose spanners.
I got a local shop to change oil & filter (genÆ Mitsu), & check oil pressure,
Pressure results, mid 20Æs psi @ 1000rpm & mid 40Æs psi @ 3000.
I did ask for pressure readings @ 1000, 1500, 2000, 2500, 3000 & 3500 but I only got the 2 above.
Shop foreman said I need to replace the lash adjusters in both heads and has quoted ú385 ($750) to do the job.
IÆve tried revving the engine to 3000rpm/idle..repeat..repeat as per the Mitsu manual a number of times, I lost count, sounded like the tick had gone. Drove around the block & it was back. I will try a lifter flush oil additive tonight & see how that goes.
Questions:
Could the problem be elsewhere? Difficult to say I know butààààààoffers
Is replacing the VLAÆs a job for a novice, like me? Yes another difficult one.
I have a Haynes manual + others from the net etc & it looks not too bad. Is the tool to hold the VLAÆs in place while removing the rocker assembly essential? One lost VLA down an oil passage & IÆm toast, along with the engine.
Shogun (Pajero/Montero) 3.0L V6 12valve LWB Auto 1993
142k miles.
Dual Bouncy Seats
Totally stock
c/w Diff lock
now sold
Re: tick...tick...tick...tap....tap...tap...TAP..TAP..TAP......VLA help [Re: Steve Nichols] #860956 01/18/08 08:45 PM
Not hard, just tedious. You have to do the same steps as a timing belt renew, plus pull the rocker arms off the heads, then just soak the new ones in diesel fuel overnight, "pumping" the plunger first while submerged, and put it back together. Heads do not have to come off, but I'd retorqued them while I was all the way in there.
Re: tick...tick...tick...tap....tap...tap...TAP..TAP..TAP......VLA help [Re: fasteddy] #860957 01/19/08 05:41 PM
F
fhuzz Offline
I can't vouch for this stuff but I thought I'd give it a try...
Mitsubishi recommends running the BG MOA with every oil change (and the 44K once a year) and that does seem to help A LOT. I have the '97 3.0L engine with the screwed up cam followers - Mitsu claims they made the blead holes too small - and had the ticking problem even when it was new. Dealership recommended using the MOA and that took care of 99% of the problem.
Just another thought BG MOA
'89 Monty LWB auto, 3rd row seating, 95SR rear + coils, genII UCA's and calipers/rotors, dual bouncies.
Re: tick...tick...tick...tap....tap...tap...TAP..TAP..TAP......VLA help [Re: fasteddy] #860958 01/19/08 09:34 PM
sparkem Offline
Just take the air plenum off and valve covers off and unbolt the rockers. No need to take the timing belt stuff off. Not to bad of a job.
Re: tick...tick...tick...tap....tap...tap...TAP..TAP..TAP......VLA help [Re: sparkem] #860959 01/20/08 06:01 PM
Sparkem
That was the impression I got from reading the manuals, but the idea of getting in as deep as a timing belt change bothers me. <img src="/forums/images/graemlins/scared.gif" alt="" />
SteveN
142k miles.
Dual Bouncy Seats
Totally stock
c/w Diff lock
now sold
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6078 MB (Peak: 0.6740 MB) Data Comp: Off Server Time: 2026-06-23 03:56:41 UTC
