Super Alloy 5 #861282 01/19/08 10:48 PM
Grasscat Offline OP
Have any of you ever use this stuff before, if so what where your results?
Super Alloy 5
Michael j
TreadLightly! Trainer
Re: Super Alloy 5 [Re: Grasscat] #861283 01/20/08 02:37 AM
88SuperTrooper Offline
My dad had some rod like that. It works pretty well. We tried it on an Aluminum Pop Can and it worked really well. put a hole in the botton of the can and took a propane torch it the can to get it hot and then did the same to the rod and it went right to the hole and sealed it up. Filled it with water, and it held a good seal. I never really used it for anything myself. But he used it on his boat for the aluminum Trim and tie off points that broke on him. and his truck box as well.
I personally have never used it. Speaking from 2nd hand, lol.
Do they give samples? Id see if you can try it first before you actually bought some.
89'Isuzu Trooper LS 5 spd 2.6L
31" Big O X/T's
15x8 Eagle 058's
K&N Filter w/ Air Box Mod
2.25" DynoMax SuperTurbo
PolyUrathane/Indy4X Bushings
Suspension/ FrontEnd Tech/Hunter Certified Alignment Tech.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5884 MB (Peak: 0.6365 MB) Data Comp: Off Server Time: 2026-06-05 07:45:37 UTC
