Page 1 of 5 1 2 3 4 5
Does this sound like a fuel pump problem? #861357 01/20/08 04:07 AM
94svt50 Offline OP
Okay, here is my problem. When the truck has been sitting for a while after having been driven a good distance, long enough to heat things up. When you start it back up it runs realy rough, but it starts up just fine. Then when you push on the gas it just hesitates and bogs down unless you push it to the floor then it takes off like it should. But, when you back off the pedal from the full down position it starts bogging again. It will do this for maybe a 1/10 of a mile then it runs like normal. It never does this when the car has been sitting long enough for every thing to cool down, like a couple hrs. And it always starts right up initialy no matter if its hot or cold. Im leaning towards a fuel pump problem, maybe when the fuel pump soaks up some heat it starts fritzing out until enough cool gas runs thru it to cool it off.
What do you all think? any other possibilities?
Thanks-jon
-1989 4x4 22re(pretty good in the mud)
- custom steel flat bed-oneside of exhaust system, and air box intake off cobra.(doesnt quite have the v8 rumble)AFM off '82 Supra.
-Destination M/T 31"-KYB monomax shocks-"add a leaf"
Re: Does this sound like a fuel pump problem? [Re: 94svt50] #861358 01/20/08 04:20 AM
4Crawler Offline
Could always try the fuel pump test jumper to see if it is an electrical type issue (will force the pump to run):
http://www.4crawler.com/4x4/CheapTricks/index.shtml#FuelPump
Re: Does this sound like a fuel pump problem? [Re: 4Crawler] #861359 01/20/08 03:08 PM
94svt50 Offline OP
Would an electric problem be so temperature sensitive? I once had an 89 mustang that did somewhat of the same thing and it ended up being the fuel pump. Just didnt know if anyone had to deal with a similar problem and had solved it.
-thannks jon
Re: Does this sound like a fuel pump problem? [Re: 94svt50] #861360 01/22/08 03:13 AM
94svt50 Offline OP
What about a sensor? could some sensor cause a quick problem then work fine?
Re: Does this sound like a fuel pump problem? [Re: 94svt50] #861361 01/22/08 03:17 AM
4Crawler Offline
Yes, the Air Flow Meter controls the fuel pump and if you have an intermittent connection in that part of the circuit, the fuel pump can cut in and out as you drive (I had that very same problem). Doing the fuel pump test jumper, as noted above, is one way to troubleshoot that sort of problem:
http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml
Re: Does this sound like a fuel pump problem? [Re: 4Crawler] #861362 01/27/08 03:06 AM
94svt50 Offline OP
This is definetly a temperature related, heat soak type problem. It only happens when the truck is hot and then parked for a period of time 5-20 minutes then started again. It then runs rough, stalling and bucking except if pedal is punched to floor, then it starts again as soon as pedal comes back off floor. It does this for 2-3 minutes and then runs fine untill shut off for that period of time. When the engine is completely cold it starts and runs fine perfectly and is perfect after intial 2-3 minutes on a hot motor that has set for 5-20 minutes.
Re: Does this sound like a fuel pump problem? [Re: 94svt50] #861363 01/30/08 03:07 AM
94svt50 Offline OP
Re: Does this sound like a fuel pump problem? [Re: 94svt50] #861364 01/30/08 03:52 AM
4Crawler Offline
Have you tried the fuel pump test jumper?
Is the fuel pressure regulator vacuum line hooked up properly?
- http://www.4crawler.com/4x4/CheapTricks/22RE_Engine_Pix/9.html
Re: Does this sound like a fuel pump problem? [Re: 4Crawler] #861365 02/02/08 05:43 PM
A
aptech Offline
try the test then we can move on. crawler usually knows what he is alking about. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Does this sound like a fuel pump problem? [Re: aptech] #861366 02/03/08 02:38 AM
94svt50 Offline OP
I dont doubt that he does. But, this problem is directly temperature related and Im not sure if that test would be conclusive or not in my situation, though I do appreciate the replys.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6419 MB (Peak: 0.7657 MB) Data Comp: Off Server Time: 2026-06-17 00:51:17 UTC
