P0137 and Oil all over the motor. #861552 01/21/08 01:53 AM
Chris_Eichman Offline OP
I have a check engine light. The code came back P0137. When I opened the hood there was oil all over the passenger side of the motor. I thought maybe the filter had come loose and some oil had come out, but I replaced the filter refilled the oil and cleared the code. Well 15 miles later the code and oil were both back! Any ideas?
Thanks,
Chris
Re: P0137 and Oil all over the motor. [Re: Chris_Eichman] #861553 01/21/08 02:15 AM
bombardj1 Offline
p0137 is the rear O2 sensor the oil most likely is a leaky valve cover gasket, the O2 sensor connector might have oil all over it, one place you can check for the oil from the gasket is down from the pcv it will pool there in a pocket of the head. then get back with us.
Re: P0137 and Oil all over the motor. [Re: bombardj1] #861554 01/21/08 03:15 AM
There is a definate pool down from the PCV valve. That most likely means valve cover gasket then? If I remember correctly there is a set of instructions for changing the valve cover gasket at the top of this forum, right?
Thanks!
Re: P0137 and Oil all over the motor. [Re: Chris_Eichman] #861555 01/21/08 03:59 AM
Lou Offline
There have been a few occurrences of the oil filter adapter coming loose from the engine block. What you describe sounds to be more than a valve gasket leak and too sudden ....
I changed my valve gasket last summer....rather straight forward..piece of cake
www.avigex.ca/kia/gasket1.JPG
www.avigex.ca/kia/gasket2.JPG
www.avigex.ca/kia/gasket3.JPG
Re: P0137 and Oil all over the motor. [Re: Chris_Eichman] #861556 01/21/08 04:01 AM
bombardj1 Offline
use a kia or felpro gasket others are to thin, also use ultra grey rtv sealant in the corner of the cam lobes, I believe www.kiatechinfo.com will give you the locations also and torque, if you have not change the wires and plugs might want to think about doing them the same time. use anti-seize cream on the plugs.
Re: P0137 and Oil all over the motor. [Re: bombardj1] #861557 01/21/08 03:29 PM
Hydra747 Offline
Awesome logical deducement!!!
Just spray the O2 sensor connector with electrical degreaser and DO NOT buy another sensor.
Then take care of the Gasket issue (do not forget to change the PCV) at that point.
Do the spark plugs and wires while you are at it!!!! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: P0137 and Oil all over the motor. [Re: Hydra747] #861558 01/21/08 07:44 PM
Thanks for all the help! Hopefully I can get to it this weekend!
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.011s) Memory: 0.6167 MB (Peak: 0.6924 MB) Data Comp: Off Server Time: 2026-11-04 22:38:45 UTC
