Re: TJ Springs
[Re: Nukeiridium]
#861630
01/21/08 09:30 PM
It does, but I was just wondering after you need to replace the rear shocks.........Can you use the rav 4 ones????
Re: TJ Springs
[Re: Nukeiridium]
#861631
01/24/08 04:51 AM
How the ***** did you break a spring??? <img src="/forums/images/graemlins/zombie.gif" alt="" /> Ever watched The Dukes of Hazard? Yeeeeee Haaaawwwwwwwwwwwwwww! <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
08' Jeep Wrangler 64' Plymouth Sport Fury 383 58' Triumph TR-3A
Re: TJ Springs
[Re: Everet]
#861632
01/24/08 05:48 AM
why do you have to get longer shocks? i thought you could just run your stock ones
cone filter, boche platinum 4 plugs, 235/75/15 kumho all terrains jeep tj rear springs and rav 4 rear shocks, rocksport gear 4" front springs, warn manual hubs, 2.25 inch exhaust, no cat, 48" thrush glasspack
Re: TJ Springs
[Re: wyodriver4]
#861633
01/24/08 06:14 AM
You could run the stock shocks, but if you do, you won't get as much articulation in the rear as you could with a longer shock. It's better to run the longest shock you can without the spring falling out or the shock bottoming out at full stuff.
2002 Sportage 4dr 4x4 soon to undergo an Extreme Makeover!
Re: TJ Springs
[Re: wyodriver4]
#861634
01/24/08 02:33 PM
why do you have to get longer shocks? i thought you could just run your stock ones if you only lift about 1-1.5" you can run stock shocks. with 4" the shock will top out over bumps in the road and can bounce the tire off the ground, really not good.
95 Sportage w/welded and 5.89 geared dana 44's on 38.5" TSL's.- SADLY SOLD CURRENTLY - 2000 sportage, 5.38 gears, welded diffs, 35" tires, 5.5" lift http://www.cardomain.com/ride/341410
Re: TJ Springs
[Re: Dave Scott]
#861635
01/24/08 07:12 PM
and for the front end???? Nothing??? Dont the front ones after a lift work at the end of their capasity?? Dave at your kit you have new higher fron springs.. but socks?????
'96 4d mechanicaly stock so far, rims, spoiler, Cooper AT tyres, Factory LSD, Manual Warn Hubs, handmade exaust, ELECTRIC FAN!!! 3,1'' Lift, PALM GPS http://members.cardomain.com/fokion
Re: TJ Springs
[Re: fokion]
#861636
01/24/08 07:21 PM
well rears you can use the rav4 shocks, so they are available.
the problem on the front is nobody makes a longer strut assembly.
BUT you are pretty much at your max drop once the upper control arm stops the travel. if you pop off the upper control arm it will go farther down, but then your CV angles are too severe to even be usable.
with daves springs in without the upper control arm mounted, you can't turn the wheel, or at least not easily due to the cv angle.
only way around that issue is SAS. OR drop the front diff down a few inches, and make custom mounting points for the a-arms. 4" is the MAX I would run up front.
Sportage sold......... 1999 4runner 4x4 , Tundra brake rotors and calipers (well worth it!) -wifes
Re: TJ Springs
[Re: fokion]
#861637
01/24/08 08:03 PM
and for the front end???? Nothing??? Dont the front ones after a lift work at the end of their capasity?? Dave at your kit you have new higher fron springs.. but socks????? i give the stock strut a little extra room to move. see, in order to lift the front 4" the coils only need to be roughly 2-2.5" taller. the front strut already has about 4.75" of stroke, more extension than compression at stock ride height, so, by building the upper strut mount with a flat top, minus the bell-shaped area, and trimming the bumpstop to about 1/2 or 1/3 it's stock length, one can keep most of their up travel and gain about 2" down travel. to be honest, the strut, at ride height, with my 4" kit, sits only about 3/4" further extended than it would from the factory. this leaves about 4-4.5" of extension and 4.5-5" of compression measured at the top of the tire. so, no, the strut will only top-out when getting REALLY flexed-up or taking a corner WAAAYYYY too fast.
Re: TJ Springs
[Re: jaybur]
#861638
01/24/08 08:07 PM
only way around that issue is SAS. OR drop the front diff down a few inches, and make custom mounting points for the a-arms. 4" is the MAX I would run up front. yeah, 4" is max. BUT, a long-travel IFS set-up would also increase front wheel travel and bigger CV's would allow more angle. someday, someday.....
Re: TJ Springs
[Re: Dave Scott]
#861639
01/24/08 08:59 PM
All this talk about the 4" RSG lift is getting me excited...
Gonna install mine during spring break, and then summer is going to be fun times <img src="/forums/images/graemlins/smile.gif" alt="" />
