Page 5 of 5 1 2 3 4 5
Re: TJ Springs [Re: Chris_Eichman] #861660 01/29/08 03:47 PM
Hydra747 Offline
RIF.....(Reading is Fundamental)! <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: TJ Springs [Re: Hydra747] #861661 01/29/08 03:55 PM
Hydra747 Offline
Starting to sound like our new Moderator (Gary) <img src="/forums/images/graemlins/barf.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/nana.gif" alt="" />
Just kidding friend <img src="/forums/images/graemlins/kewl.gif" alt="" />
Check this out: web page
Re: TJ Springs [Re: jaybur] #861662 01/29/08 05:02 PM
jaybur Offline
well the higher the spring rate, the higher it will sit in the rear. they are all the same length, just a different spring rate.
I do not know honestly how much of a difference. but I read somewhere that a spring out of a rubicon hardtop (the 106) would lift a regular tj 1-2" but I could not find any other info on that being true.
Sportage sold.........
1999 4runner 4x4 , Tundra brake rotors and calipers (well worth it!) -wifes
Re: TJ Springs [Re: jaybur] #861663 01/29/08 05:52 PM
DEFBOY35 Offline
rubicons are lifted from the factory, that is why they will lift the regular tj's the 2"
a stiffer spring rate will give you a harsher ride, all depends on how much higher it is. it will also allow for more weight, which is why they put a higher spring rate in the hard top models to compensate for the extra weight and maintain the same ride characteristics.
in our case from what i have heard is that the tj springs are stiffer than ours to begin with, so going to the highest spring rate would lift a little more and be a slightly harsher rider. may not absorb the bumps as well.
2000 SPORTY, DEF BOY customs, mmm....lockers, mmm... gears, mmm... double transfer case, mmm... stroker
http://www.cardomain.com/ride/2377991
Re: TJ Springs [Re: DEFBOY35] #861664 01/29/08 07:08 PM
jaybur Offline
i read on some site that the rubicons are not lifted. they just look that way. the springs are the same length.
Re: TJ Springs [Re: jaybur] #861665 01/29/08 07:19 PM
Dave Scott Offline
they aren't lifted, they just come with a 31" tire and a much stiffer coil spring set. the stiff coils are for a couple different reasons, so they can handle the abuse of really getting used off-road and so that the tires don't rub as much under compression.
during the early 90's Jeeps came from the factory with an optional 1" UpCountry brand lift. they discontinued that in the late 90's or very early 2000's.
Re: TJ Springs [Re: Dave Scott] #861666 01/29/08 07:41 PM
DEFBOY35 Offline
ok, i stand corrected then!!! <img src="/forums/images/graemlins/kewl.gif" alt="" />
funny thing was it was a jeep guy that gave me the info!!
Re: TJ Springs [Re: DEFBOY35] #861667 01/30/08 01:09 AM
Iron Offline OP
Must have been the same guy i spoke too, I was told me the springs on the sahara and rubicon where taller than the base TJ/wrangler!
08' Jeep Wrangler
64' Plymouth Sport Fury 383
58' Triumph TR-3A
Re: TJ Springs [Re: Iron] #861668 01/30/08 12:56 PM
Hydra747 Offline
I always thought that they were lifted too! <img src="/forums/images/graemlins/confused.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.006s) Memory: 0.6354 MB (Peak: 0.7567 MB) Data Comp: Off Server Time: 2026-06-13 09:40:54 UTC
