rear case swap-tcase slip to fixed yoke #861999 01/22/08 12:50 PM
Bansil Offline OP
Ok 90-ish Amigo with 5spd and standard shifting tcase with slip yoke output.
I need a fixed output,I know it's a basic swap just r&r the pcs.
What year fixed output case do i need?
Will a SOTF rear case bolt up or what?
I have several SOTF cases.
I assume the shift rails would be different.
I don't need the front wheel drive shifter on the old slip yoke case,so that doesn't matter,and without pulling tranny and t-case to experament with I don't know.
What I want to do is keep the front case attached to the 5spd and just swap a fixed yoke case rear part.
TIA
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
Re: rear case swap-tcase slip to fixed yoke [Re: Bansil] #862000 01/22/08 05:39 PM
RobG Offline
does it matter for what you're doing? granted when I did my conversion over, I installed Tera's at the same time so I was using their hi-lo shift rail, but besides that, I didn't need any of the rails from the donor case. just the cover w/ its output cluster, hi-lo gear and clutch, and 4wd gear (again I was using Tera's).
-Rob
Re: rear case swap-tcase slip to fixed yoke [Re: Bansil] #862001 01/22/08 06:42 PM
Bansil Offline OP
No not really <img src="/forums/images/graemlins/smile.gif" alt="" />
Just wasn't sure about the depths of the SOTF compared to Non-SOTF case.
This looks like a go,Thanks
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5936 MB (Peak: 0.6479 MB) Data Comp: Off Server Time: 2026-06-19 03:24:43 UTC
