Page 31 of 95 1 2 29 30 31 32 33 94 95
Re: Crashed [Re: TayJ] #862756 01/20/09 08:57 PM
hazy_daze Offline
Sounds like a SAS and a Sawzall are in order.
Re: Crashed [Re: hazy_daze] #862757 01/21/09 12:04 AM
lordtrunks Offline
man that sucks dude, at least you can fix it.
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: Crashed [Re: lordtrunks] #862758 01/21/09 12:11 AM
lordtrunks Offline
If you need a new upper a-arm and balljoint justice had posted up some cheap aftermarket ones, that i was thinking about trying out.
Re: Crashed [Re: lordtrunks] #862759 01/21/09 12:25 AM
TOASTY Offline OP
Well if you give up, DIBS. That's really ghey someone ***** with your *****, maybe the tire shop over torqued the nuts. Are the studs gone?
So you wheeled it with minimal rubbing, i assume you've got sway bars on? and post some pics of the truck with 35's!
Re: Crashed [Re: TayJ] #862760 01/21/09 12:27 AM
TOASTY Offline OP
Oh and it is undrivable now, but I have some parts and hoefully will have it back on the road today. I do need lugs nuts though.
Those control arms from the parts truck are shorter, you could swap everything and be narrow up front though.
Re: No camping [Re: ClayTK] #862761 01/22/09 04:15 AM
No Clay, she's not hot. And she's even older than I am. But if that's what you're into...
Re: No camping [Re: JohnnyBfromPeoria] #862762 01/23/09 05:43 AM
TayJ Offline
Well, I got the old Mitsu all fixed and RE-painted. Looks good again. Got my cb installed too. Next I am doing belts, hoses, timing belt, radiator test and flush, plugs, wires and cap! Should be running real good after all that. I am also going to fix the small oil leak I have coming from the cooler lines. Don't know yet if I am going to drop the t-case again and reseal it but that leak is annoying me! As for the sway bars, I am only running the rear one right now, I almost had it on its side the other day and I bet that sway bar was the only thing holding it from going over. I might take it off one of tese days, its not as dangerous as you all think, esp with only te rear one. I would go take a pic but it is night so you wouldn't see anything. Toasty, wy don't you come by the auto shop where I work and check it out?
Jeep
Jus' sayin'
Re: No camping [Re: TayJ] #862763 01/23/09 07:51 AM
TOASTY Offline OP
you almost had it on its side? you mean when the wheel came off?
I just went back to work full time, i won't be in Aj for a while. I'll call you when i go out there to pick up my 9 inch from LT. You and the missus should come over more often it's been a while.
Re: No camping [Re: TOASTY] #862764 01/24/09 03:43 AM
TayJ Offline
Jeep
Jus' sayin'
Re: No camping [Re: TOASTY] #862765 01/24/09 03:47 AM
TayJ Offline
I almost had it on its side when I was wheeling. When the wheel came off I just slide off the road. I don't work in AJ, I work in Mesa. So I can come by tomorrow, just me the kid and the mitsu beast! Well, I can come over if I get this BMW unhooked from my Mitsu, I had to tow it for a friend, I should put a pic of that on here tomorrow, looks funny! Tomorrow? What you doin?
Jeep
Jus' sayin'
Moderated by  4x4Wire, TOASTY
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.011s) Memory: 0.6531 MB (Peak: 0.7610 MB) Data Comp: Off Server Time: 2026-06-21 00:09:18 UTC
