Page 40 of 95 1 2 38 39 40 41 42 94 95
Re: Man this place is happenin' [Re: ClayTK] #862846 02/03/09 04:35 PM
TayJ Offline
When I did the tranny swap I blew the cooler lines out with air to make sure there wasn't a clog. I have less than 500 miles on this tranny since the swap. The lines shouldn't be clogged again. And I have an external tranny cooler, the lines go into the radiator first and then the external cooler. Are you saying I should unhook the lines to the radiator? Bypassing it and only use the external cooler?
Jeep
Jus' sayin'
Re: Man this place is happenin' [Re: TayJ] #862847 02/03/09 05:30 PM
TOASTY Offline OP
A lot of people bypass the radiator, If you need a second tranny cooler I'm the man. Actually I'll add that to my garage sale. Give me a call Tay.
Re: Man this place is happenin' [Re: TayJ] #862848 02/03/09 05:33 PM
TayJ Offline
If I can't get this figured out by tonight then I am going to sell it. I am going to put it on Craigslist for 1500 but if someone offers 1000 I'd take that. Then I am going to take that money plus some other money and buy a newer Montero thats in better shape and is good to go.
Jeep
Jus' sayin'
Re: Man this place is happenin' [Re: TOASTY] #862849 02/03/09 05:34 PM
TayJ Offline
If I bypass the radiator how will I know if my tranny is running hot or not? And is the radiator the problem here? Or is it the tranny? Or something else? I couldn't get ahold of pat last night.
Jeep
Jus' sayin'
Re: Man this place is happenin' [Re: TayJ] #862850 02/03/09 06:22 PM
TayJ Offline
I just found a 2000 Jimmy with the 4.3L, auto trans and 4x4 t-case. The truck is missing parts like door handles, rear end and driveline and other small parts. All the engine, tranny, t-case, computer parts are there. Truck runs and tranny/t-case work. I can buy the whole truck for 500. Engine has 143000 on it. What do you guys think about that instead of selling my Mitsu or putting another tranny in it?
Jeep
Jus' sayin'
Re: Man this place is happenin' [Re: TayJ] #862851 02/03/09 08:36 PM
TOASTY Offline OP
I'd get a newer SR that way you get the locker and more power with less work. I'd buy your thing but you know my situation, unless you might want to trade for a tracker? <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Man this place is happenin' [Re: TayJ] #862852 02/03/09 11:11 PM
Oyaji_Jon Offline
Good engine. I'm using same gen 4.3. The wiring harness will be a pain in the @ss to go through, but is documented on line if you have the patience. Computer will need flashed for operation in another vehicle without VATS. In cali the setup can be smogged if you keep all emissions equipment functional and use the factory trans. I know nothing of the t-case that's in that rig.
All that said, I'd say go for it. You can pay someone to go through the harness and flash the computer. I can put you in touch with a guy whose been doing these swaps smog legal for a while now...
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: Man this place is happenin' [Re: Oyaji_Jon] #862853 02/04/09 12:25 AM
lordtrunks Offline
Tay you work at a auto shop right don't you guys have what i think is a a infrared pyrometer you can use that to check the temps on one side of the cooler vers the other and see if its really doing its job or not, and you'll also see how hot its really getting.
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: Man this place is happenin' [Re: lordtrunks] #862854 02/04/09 12:33 AM
TOASTY Offline OP
Blizm with the flip flop! this is talk get yourself a tech post Tay! What's up LT? <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Man this place is happenin' [Re: TOASTY] #862855 02/04/09 04:14 AM
TayJ Offline
We are only chatting. Anyways, we believw we know the issue and can fix it. I am gonna fix it and then sell it and might buy a 95 Sr.
Jeep
Jus' sayin'
Moderated by  4x4Wire, TOASTY
PHP: 7.4.33 Page Time: 0.021s Queries: 15 (0.018s) Memory: 0.6499 MB (Peak: 0.7579 MB) Data Comp: Off Server Time: 2026-07-13 19:41:24 UTC
