Page 56 of 95 1 2 54 55 56 57 58 94 95
Re: Az crawler crew [Re: JohnnyBfromPeoria] #863006 02/26/09 09:07 PM
shogun Offline
<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
1985 mitsubishi montero, rebuilt engine and carb.
Re: Az crawler crew [Re: shogun] #863007 02/26/09 09:19 PM
shogun Offline
well, it all started when my motor was installed, ( manufactured engine from engines exhcange) she was slightly smoking. So then i went to carb exchange(not the same co.)i purchased a remanufactured carb.it passed emissions with no problem.
She still smells like fuel, and so does the oil. i then took it to the ppl who built the engine, and they said it was ok and nothing was wrong with it. For a while she wouldnt smoke(it looked white to dark.So now when i drive and i accelerate switching gears i feel a slight bogging( but she wont die).
Then i notice that shell smoke when im sitting at a light, but not while im driving. Now she just doesnt want to accelerate real slow. Now my right hand side is vibrating with a sligh burn smell. I know you guys have seen me submitt this info more that once, but ive been trying to keep up with all these
messages. thanks !!!!!!!!!!!!!!
Re: Az crawler crew [Re: shogun] #863008 02/26/09 09:47 PM
Hmmm. Compression test, then retest any cylinder that's more than 15% lower than the others after adding a couple of teaspoons of motor oil through the spark plug hole. That'll tell us whether there's a ring problem or a head/valve/guide problem. Toasty, any of you guys have a tester out that way?
Front end...hmmm, let's check the brake caliper to see if it's sticking. I have two extras if it is. Also probably not a bad time to repack the wheel bearings and re-torque them. I've been asking the 'Crew for years...can someone grind down my Chevy spindle socket so there are only two lugs instead of the six that are on it? That way all of us will have the proper tool and not be using needle nose pliers on them anymore.
Re: Az crawler crew [Re: JohnnyBfromPeoria] #863009 02/26/09 10:01 PM
shogun Offline
I repacked both bearings, and man those dang bolts are expensive, $5.28, a pop!!
Re: Az crawler crew [Re: shogun] #863010 02/26/09 10:51 PM
Did you torque them in per shop manual procedure? What kind of grease? And what bolts are you referring to?
Re: Az crawler crew [Re: JohnnyBfromPeoria] #863011 02/26/09 11:05 PM
shogun Offline
those 6 bolts and yae i greased them. the one's that look like stars?
Re: Az crawler crew [Re: shogun] #863012 02/26/09 11:18 PM
Allen head bolts.
So did you follow shop manual procedure to reseat the bearings and set their torque correctly?
Re: Az crawler crew [Re: JohnnyBfromPeoria] #863013 02/26/09 11:39 PM
shogun Offline
yea,
Re: Az crawler crew [Re: lordtrunks] #863014 02/27/09 02:20 AM
kewlynx Offline
az crew stick together we want him here lynx, <img src="/forums/images/graemlins/smile.gif" alt="" /> besides archiving the same old carb questions doesn't really help anyone. <img src="/forums/images/graemlins/kewl.gif" alt="" /> I dig the avatar cuz i dig.
I understand, but this thread doesn't get archived, either.
One of you guys should write a carb article for the Wire. <img src="/forums/images/graemlins/wink.gif" alt="" />
**ubi apis- ibi salus**
Re: Az crawler crew [Re: kewlynx] #863015 02/27/09 02:32 AM
PA_JERO Offline
I don't think any of us really know much about the carbs, we mostly just get really ticked off with them and then resort to a weber conversion as we throw the mikuni in the garbage. I finally decided that weber is way more reliable and alot cheaper.
Moderated by  4x4Wire, TOASTY
PHP: 7.4.33 Page Time: 0.024s Queries: 15 (0.021s) Memory: 0.6506 MB (Peak: 0.7598 MB) Data Comp: Off Server Time: 2026-07-14 05:22:36 UTC
