Page 68 of 95 1 2 66 67 68 69 70 94 95
Re: AttN all AZ Crew [Re: monte3] #863126 03/15/09 12:40 AM
PA_JERO Offline
The truck looks great jbfp, how's she ridin now?
Re: AttN all AZ Crew [Re: PA_JERO] #863127 03/15/09 01:38 AM
wrenchwench Offline
So tomorrow I'm headed out for a light duty ride on some dirt.. maybe a little 4l if an opportunity presents itself. Haven't decided where yet, anyone else up to burn some ga$oline? <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: AttN all AZ Crew [Re: wrenchwench] #863128 03/15/09 02:30 AM
TOASTY Offline OP
No, but i did get my old job back so once i catch up on bills i will be wheeling first thing. Oh i have to move first i didn't have enough money to renew my lease. <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: AttN all AZ Crew [Re: TOASTY] #863129 03/15/09 02:44 AM
wrenchwench Offline
Sweet congrats on gainful employment!!!!!
need cv's [Re: wrenchwench] #863130 03/15/09 05:31 AM
motero Offline
We are getting settled in our house out in Wittmann. Do any of you have a set of C/V Shafts, for a 99monty, you would part with, preferably with the boots intact. Mine are clicking up a storm the boots have been torn for months, and I have had no where to fix them till now. Or do you think new grease and boots would fix it? Or do you think I should tear it down first and see how bad the damage is in the joints.
Thanks, can't wait to hit the trails.
99 Montero....15mpg! Sold (so sad)
02 Jetta TDI....48mpg!
03 2500 Ram QCLB Cummins....18mpg
02 2500 Yukon XL, We out grew the montero, at least it has one locker.....13mpg (sold)
01 montero limited
Re: need cv's [Re: motero] #863131 03/15/09 06:27 AM
TOASTY Offline OP
I know where some are, and if they are clicking they're F'd. If you get a used set even with good boots you will want to put new boots on or they'll tear right away, especially if you're running a lift.
Re: need cv's [Re: TOASTY] #863132 03/15/09 10:13 AM
PA_JERO Offline
Well, me and clay just rescued Brodie's truck, your white one Johnny. A piston went through the block. the motor is f'd, the head might be able to be salvaged, not sure yet. The good news is that it was the wooden piston though. More on this as it developes.
Re: need cv's [Re: PA_JERO] #863133 03/15/09 10:53 AM
ClayTK Offline
GAAAAR Kevin, i knew u would try to beat me to it!
My guess is the bolts for the retainer for the piston rod backed off due to wrong torque spec, or the bearing went bad and the piston was freed from the crank then came up and slapped the head then on its way down the rod hit one of the lobes on the crank shaft and pushed it out the side of the block. It is a sad day <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: need cv's [Re: ClayTK] #863134 03/15/09 03:17 PM
wrenchwench Offline
Here ya go
Trousers.
Re: need cv's [Re: wrenchwench] #863135 03/15/09 03:28 PM
wrenchwench Offline
Oh btw... anyone know a shop here in the general phoenix area that's open on Sunday? I need a shop with a TechII scanner or equivalent to do a crank relearn procedure on my 4.3.
Moderated by  4x4Wire, TOASTY
PHP: 7.4.33 Page Time: 0.023s Queries: 15 (0.020s) Memory: 0.6487 MB (Peak: 0.7738 MB) Data Comp: Off Server Time: 2026-07-13 20:34:53 UTC
