Dome light, or dumb light #863590 01/24/08 02:03 PM
OldColt Offline OP
I see in a post a mention about a done light that works intermittently.
Generally Dome light failures in a Mitsubishi, call it most all Mitubishis is due to one of two things.
Very common the rivets holding the light assembly together settle into the plastic, this allows the parts in the light to loosen and resistance builds within the assembly causing failure.
The other failure mode are faulty door switches, this can be one or all on a vehicle.
Does your dome light work?
single choice
Votes accepted starting: 01/24/08 06:00 AM
You must vote before you can view the results of this poll.
Re: Dome light, or dumb light [Re: OldColt] #863591 01/24/08 02:16 PM
hazy_daze Offline
Gotta wiggle my door switch most mornings. I've even taken it out and cleaned/lubed it. To no avail. Not a high priority on the repair/upgrade list <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Dome light, or dumb light [Re: hazy_daze] #863592 01/24/08 03:43 PM
Mad_Scientist Offline
I need to fix mine. It always works with the door open but not if I just switch it on in the cab. It's actually a bit of a pain so I should fix it <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Re: Dome light, or dumb light [Re: hazy_daze] #863593 01/24/08 04:15 PM
jmdt Offline
x2
My wife's Hyundai Elantra has identical looking door switches, right down to the little rubber boots that cover them. I might see if one from the hyudai fits the montero and then try to get some off a junkyard hyundai if it works.
Jim
1994 Montero LS
Re: Dome light, or dumb light [Re: jmdt] #863594 01/24/08 04:20 PM
I killed mine when I pulled the door lock fuse to "cure" a short that was holding the locks down and draining the battery. Key locks for me...
Re: Dome light, or dumb light [Re: OldColt] #863595 01/24/08 05:57 PM
RoryTek Offline
I dumped my old style lamp and went with a LED.
Rory N6OIL
88'Monty 2.6l 2dr,5spd,Silver,2 bouncy seats,LSD
Most Wanted Synthetics
Re: Dome light, or dumb light [Re: RoryTek] #863596 01/24/08 06:38 PM
I put in a SignalStat commercial light fixture from my local auto parts store...uses an 1156 light bulb...really bright!
Re: Dome light, or dumb light [Re: OldColt] #863597 01/24/08 06:53 PM
Grasscat Offline
Mine is " Yes, sweet and reliable ", might be because of where it lives. <img src="/forums/images/graemlins/smile.gif" alt="" />
Michael j
TreadLightly! Trainer
Re: Dome light, or dumb light [Re: Grasscat] #863598 01/24/08 08:56 PM
DirtDriver Offline
Both my cab and rear dome lights work intermittantly, although they usually only stop working when I need them. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
1990 Monty LS 3.0 A/T LWB. KYB front shocks, OME rears and coils. 33x10.5 BFG Muds. 5.29, 2.85, RD110, RD46. 2 bouncys. Aisins. Monte Disco swaybar disconnects. GenII t-arms, idler arm, UCA's, V45W front brakes. 2in BL.
Re: Dome light, or dumb light [Re: DirtDriver] #863599 01/25/08 01:36 AM
Jamez Offline
Although its only useful when VERY dark, it still works.
'87 Raider w/rebuilt 2.6
Weber 32/36
PHP: 7.4.33 Page Time: 1.120s Queries: 19 (0.004s) Memory: 0.6567 MB (Peak: 0.8267 MB) Data Comp: Off Server Time: 2026-05-30 08:57:02 UTC
