Dome light, or dumb light
#863590
01/24/08 02:03 PM
I see in a post a mention about a done light that works intermittently.
Generally Dome light failures in a Mitsubishi, call it most all Mitubishis is due to one of two things. Very common the rivets holding the light assembly together settle into the plastic, this allows the parts in the light to loosen and resistance builds within the assembly causing failure. The other failure mode are faulty door switches, this can be one or all on a vehicle.
Re: Dome light, or dumb light
[Re: OldColt]
#863591
01/24/08 02:16 PM
Gotta wiggle my door switch most mornings. I've even taken it out and cleaned/lubed it. To no avail. Not a high priority on the repair/upgrade list <img src="/forums/images/graemlins/smile.gif" alt="" />
[Re: hazy_daze]
#863592
01/24/08 03:43 PM
I need to fix mine. It always works with the door open but not if I just switch it on in the cab. It's actually a bit of a pain so I should fix it <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
[Re: hazy_daze]
#863593
01/24/08 04:15 PM
Gotta wiggle my door switch most mornings. I've even taken it out and cleaned/lubed it. To no avail. Not a high priority on the repair/upgrade list <img src="/forums/images/graemlins/smile.gif" alt="" /> x2 My wife's Hyundai Elantra has identical looking door switches, right down to the little rubber boots that cover them. I might see if one from the hyudai fits the montero and then try to get some off a junkyard hyundai if it works.
Jim
1994 Montero LS
[Re: jmdt]
#863594
01/24/08 04:20 PM
I killed mine when I pulled the door lock fuse to "cure" a short that was holding the locks down and draining the battery. Key locks for me...
[Re: OldColt]
#863595
01/24/08 05:57 PM
I dumped my old style lamp and went with a LED.
[Re: RoryTek]
#863596
01/24/08 06:38 PM
I put in a SignalStat commercial light fixture from my local auto parts store...uses an 1156 light bulb...really bright!
[Re: OldColt]
#863597
01/24/08 06:53 PM
Mine is " Yes, sweet and reliable ", might be because of where it lives. <img src="/forums/images/graemlins/smile.gif" alt="" />
Michael j
TreadLightly! Trainer
[Re: Grasscat]
#863598
01/24/08 08:56 PM
Both my cab and rear dome lights work intermittantly, although they usually only stop working when I need them. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
1990 Monty LS 3.0 A/T LWB. KYB front shocks, OME rears and coils. 33x10.5 BFG Muds. 5.29, 2.85, RD110, RD46. 2 bouncys. Aisins. Monte Disco swaybar disconnects. GenII t-arms, idler arm, UCA's, V45W front brakes. 2in BL.
[Re: DirtDriver]
#863599
01/25/08 01:36 AM
Although its only useful when VERY dark, it still works.
'87 Raider w/rebuilt 2.6 Weber 32/36
