hubs
#863662
01/24/08 06:50 PM
i have the aisn hubs on my amigo. when its jacked up, when i spin the wheel should the half shaft axle turn with the tire when the hubs are unlocked?
Re: hubs
[Re: lowflying90]
#863663
01/24/08 06:57 PM
No.
You should be able to turn the cv shaft with the tires on the ground w/hubs unlocked.
Re: hubs
[Re: Bansil]
#863664
01/30/08 04:13 PM
i can turn the passenger side axle by hand but the drivers side won't turn. could it be a wheel bearing?
Re: hubs
[Re: lowflying90]
#863665
01/30/08 06:51 PM
I doubt it. The axle goes thru the spindle and doesn't even touch the wheel bearings.
The hub sounds like it is locked it.
Take the hub off, take loose small bolts,pull cover,remove snap ring on axle shaft and then remove the 6 large allen head bolts that hold the hub body on. You should be able to turn cv easily
If not then it sounds like the roller bearing that supports the outer axle(stub axle) as it goes thru the spindle is rusted or seized up.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.5999 MB (Peak: 0.6551 MB) Data Comp: Off Server Time: 2026-06-23 00:33:09 UTCValid HTML 5 and Valid CSS
